Go to Post A HUMAN PLAYER is not a ROBOT. - cgmv123 [more]
  #31   Spotlight this post!
Unread 13-02-2011, 14:09
mswalker mswalker is offline
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
Re: CRio Connection: Buggy
We reimaged with the v28 image and things seem to be working as expected. Joe, thanks for figuring this out and fixing it!
  #32   Spotlight this post!
Unread 13-02-2011, 16:09
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
how do we update to v28 please help?
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
  #33   Spotlight this post!
Unread 13-02-2011, 20:12
Take the LabVIEW v28 image from Source Forge and drop it in:
C:\Program Files\National Instruments\LabVIEW 8.6\project\CRIO Tool\FRC Images\FRC_2011_v28.zip
Then it will appear in the cRIO Imaging Tool list.
  #34   Spotlight this post!
Unread 14-02-2011, 11:53
@ mark
Thanks ill try it when I get to build site.
  #35   Spotlight this post!
Unread 14-02-2011, 17:09
It works thank your very much.
  #36   Spotlight this post!
Unread 15-02-2011, 00:08
thE_iyE's Avatar
thE_iyE thE_iyE is offline
FRC #3225 (Wolverine Robotics)
Team Role: Student
thE_iyE is an unknown quantity at this point
Just to cover some bases for ChaosX73:
Originally Posted by ChaosX73 View Post
It's not the fact that there is no code, it's the fact that for some reason, the CRio doesn't want to admit that it's connected to my computer. My mentor said something about the CRio being "Bricked" but I have no idea what that means.
I can't seem to image the cRio from my personal laptop, so I have to use the classmate. I 'bricked' (which means to turn it into an expensive paper-weight) our cRio by using the imaging tool on my laptop, so the way you have to fix it is format the cRio. You format it by putting the cRio in safe-mode. Once its in safe mode, try to deploy code using the imaging tool. It will recognize it in safe-mode and ask if you want to format it, do so. This will return it to its normal state so you can put new code on.
Its likely not bricked, so try and just deploy v28, but if your computer doesn't recognize it and the IP address doesn't seem to be recognized by your computer, its likely bricked.
Again, this is just to cover some bases for ChaosX73. Hope it helps!
Not very outgoing or authoritative in real life, but on the internet I could be a moderator.
  #37   Spotlight this post!
Unread 15-02-2011, 12:47
Turbinator Turbinator is offline
In Charge of Brain"ing" the Bot
AKA: Amninder Singh
FRC #3053 (NASA/MVB Stingers)
Turbinator has a little shameless behaviour in the past
where do we put the downloaded image on the PC so it shows up in frc crio imaging tool.
thanks
  #38   Spotlight this post!
Unread 15-02-2011, 12:49
AKA: Amninder Singh
nvm got it guys. thanks
  #39   Spotlight this post!
Unread 28-02-2011, 19:54
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Exclamation Re: CRio Connection: Buggy
Heads up.
Our team played at the Suffield Shakedown, they had the real field and FMS setup.
Our cRIO was imaged with this early release version of v28 and our robot was not able to connect to the field.
I can't say for sure if others will see this same issue at regionals, but avoid the headache an re-image asap using the official release.
  #40   Spotlight this post!
Unread 02-03-2011, 14:50
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Originally Posted by otherguy View Post
Heads up.
There is no difference. v28 is v28 regardless of how you got it.
