Go to Post Now that the robot is shipped, maybe I can get to bed before the alarm clock goes off =] - DarMagi [more]
Unread 09-02-2011, 13:41
benjaminDVBD's Avatar
benjaminDVBD benjaminDVBD is offline
FRC #3316
benjaminDVBD is an unknown quantity at this point
PhotoSensor distance
We team 3316 are trying to follow the grey lines during the autonomous period.
We want to do this by placing 3 photo sensors, with the middle one following the grey line.
The other 2 photo sensors will be placed on either side of the first one, thus if the robot moves from the line, either one of the two will tell in what direction the robot has turned. In this way the robot can know in what direction to turn in order to continue following the line (and being once more above it with the middle photo sensor).
The problem is that we don't know what the optimal distance between the sensors is.
This is relevant because if it's to close even a small deviation will be "corrected" and the robot will zigzag, and if too far, the robot might not arrive at the peg wall the way we want to.
Any suggestions/ideas?
Unread 09-02-2011, 14:07
Re: PhotoSensor distance
Design a series of tests with the sensors mounted at different distance from each other. Measure how fast the robot can follow the line, how repeatable it is, and whether the robot can get confused by approaching the line at a sharp angle. Based on that data, determine the optimal distance for your specific robot and drivetrain.
Unread 13-02-2011, 14:26
FRC #3316
Thanks for the advice!
We found the most useful distance to be 1.4 inch between each sensor.
Good luck and once more: Thank You!
