Go to Post You know, if I was John V-Neun I would get a copyright on my name! - Jay H 237 [more]
View Poll Results: Is your team using the camera to track the targets for placing tubes?
Yes 1 16.67%
No 2 33.33%
We're planning on it. 0 0%
We are using our camera for other purposes. 3 50.00%
Voters: 6. You may not vote on this poll
Unread 13-02-2011, 15:21
Re: invalid input parameter
Originally Posted by MAldridge View Post
...when I go to deploy, a window pops up stating that the cRIO cannot resolve from the current dialogue!
Whatever else might or might not be wrong, that "conflict resolution" message at least is normal behavior. It's just popping up to warn you that you're about to stop whatever tasks are already running on the cRIO in order to load a new set of software. Just say OK and let the process continue.
I'm a little concerned by your mention of "deploy", though. Normally one uses the "Run as startup" menu option.
