Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
View Poll Results: Is your team using the camera to track the targets for placing tubes?
Yes 1 16.67%
No 2 33.33%
We're planning on it. 0 0%
We are using our camera for other purposes. 3 50.00%
Voters: 6. You may not vote on this poll
Unread 13-02-2011, 11:42
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Exclamation invalid input parameter
When I open my labview project, I now recieve a popup window warning me of an invalid input parameter. This concerns me because it only happened recently after I changed the name of the .lvproj file. There are no prohibited characters in the name as the message suggests.
Also, I am now being prompted to save files that I know I didn't modify (4moterdrive.vi, imaq.vi, PID.vi). Should I save these files or not? I am very concerned about getting to the regional and then not being able to connect to the FMS.
Lastly, the cRIO has become unreachable. I was mid way through the update when one of our new freshmen ignored the lockout tag and killed the power. This of course corrupted the onboard memory. I put the cRIO into safe mode and formated it, then I used the imaging tool to restore the image with the newest version. However, when I go to deploy, a window pops up stating that the cRIO cannot resolve from the current dialogue!
Thanks in advance for any suggestions.
Unread 13-02-2011, 15:21
Re: invalid input parameter
Originally Posted by MAldridge View Post
...when I go to deploy, a window pops up stating that the cRIO cannot resolve from the current dialogue!
Whatever else might or might not be wrong, that "conflict resolution" message at least is normal behavior. It's just popping up to warn you that you're about to stop whatever tasks are already running on the cRIO in order to load a new set of software. Just say OK and let the process continue.
I'm a little concerned by your mention of "deploy", though. Normally one uses the "Run as startup" menu option.
Unread 22-02-2011, 08:57
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
I know about the window that is warning about running processes, this one is warning that the whole cRIO is not responding.
Unread 22-02-2011, 09:18
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
You have to wait up to 2 minutes for it to fully connect to the cRIO if you don't it will wait until it is connected to deploy so if you leave it to Stop Waiting or Disconnect it should just deploy when it is ready.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
