Go to Post The only odd part about this competition is that rather than further convince me that I want to be an engineer, it did the converse... I want to be a teacher. - pauluffel [more]
Unread 13-02-2011, 16:57
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: pic: Banebot P60 Failure
Our failure point was those spring pins getting torqued off the flats also. All the gears are fine. We removed the spring pins and drilled out the pin holes for larger pins going deeper into the face plate. Then put divots where the pins interface the flats for the pins to seat in. Seems better than new this way and running good now.
www.179swampthing.org
Unread 13-02-2011, 17:03
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I am very interested to hear how this works out over the long run. I wonder if banebots designed these pins to shear off first to protect something more exspensive in the assembly.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-02-2011, 18:25
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I just want to say that they did not fail under "normal" use, they failed during a test in which I tried to get them to fail.
If they can fail in a test, there's a decent chance they can fail in a real situation, too... Wouldn't you rather fix it now, instead of hoping these same circumstances can never repeat themselves in competition?
Extra chain reduction and some surgical-tubing counterbalancing could solve your problem. BaneBots gearboxes work much better when you treat them nicely...
Jeff Waegelin
Unread 13-02-2011, 20:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
You're right, we are planning on modifying a few things to make the mechanism more "nice" to the P60's, though we don't feel that a full on redesign is necessary. There's already quite a bit of surgical tubing on the arm, and we plan on adding a bit more when we get our next McMaster-Carr order. We're also considering swapping out the drive sprocket to a 10 tooth which should make the transmissions see about 33% less torque during operation - not to mention that the arm should slow down a bit too.
I'm also going to look into the modification that Swampdude suggested and see if we're able to do it in our shop.
-Dustin Benedict
