Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 13-02-2011, 15:05
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
Jaguars with 20 Amps?
Hi
are we allowed to connect FP / Window motors thruogh a Jaguar into an 20 Amp fuse, or do we have to connect it to the 40 Amp (though it sounds unlikely? )
thanks in advance
team #3083
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 13-02-2011, 15:07
Chris is me's Avatar
AKA: Pinecone
Re: Jaguars with 20 Amps?
The FP motor must run through a 40 amp breaker.
Window motors may run through a 20 amp breaker.
Unread 13-02-2011, 15:16
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
can you please address me to the source of this info in the manual? We've been searching for that...
Unread 13-02-2011, 15:28
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
The only specification I found is rule R39-A:
<R39> All active PD Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker (from the KOP or identical equivalent).
A. Each speed controller branch circuit must be protected by one and only one 20-amp, 30-amp, or 40-amp circuit breaker on the PD Board. No other electrical load can be connected to the breaker supplying this circuit.
which isn't really helping at all
Unread 13-02-2011, 16:10
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
The breaker size depends on the wire size not the motor. Cims draw lots of amps which requires 12 awg or larger wire. Wire of that gauge can use the 40 amp breaker. Window motors use around 21 amps which means it can use smaller wire and breakers. If you wanted to wire every motor with 10 awg wire. There isn't a rule that says you cant use the 40 amp breakers for all the motors!
Unread 13-02-2011, 16:15
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Originally Posted by May_Walter View Post
Are we allowed to connect FP / Window motors through a Jaguar into an 20 Amp fuse, or do we have to connect it to the 40 Amp (though it sounds unlikely? )
Yes, the rule you posted (R39 A) allows this. What makes you think it wouldn't be legal?
The FP motor must run through a 40 amp breaker. Window motors may run through a 20 amp breaker.
This isn't required by the rules, but it's definitely good practice. Like a CIM, an FP can easily pull over 40 A, and you wouldn't want it to give out on you because it tripped the breaker. If you have an unusual application where you want to limit the current to 20 A and can take the risk of a breaker popping for a few seconds, then go ahead.
On a related tangent, note that <R48 A> requires that the Fisher-Price motor be powered by a Jaguar or Victor 884, but the window motors can also be powered by Spike relays.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 13-02-2011, 17:00
There is no rule that specifies a breaker size for a motor.
The rules do require that CIM and FP motors must be controlled by a speed controller. Any legal motor can be controlled by a speed controller if variable speed and direction is needed for you application. CIM motors can be driven by a 20 amp circuit breaker if a team so wishes. However, the CIM motor may not provide the performance and the breaker will likely reset regularly producing a lot of heat in the breaker.
Unread 13-02-2011, 17:05
AKA: Pinecone
Sorry - I was quoting an outdated (2010) rule.
Unread 13-02-2011, 17:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
But a good practice!
