Go to Post They may call us geeks and nerds, but deep down under that prejudice they know they want to be the hard-core, sleep-deprived, hand drill-toting, robot builders we know we are! - vijay24 [more]
Unread 12-02-2011, 17:26
moore1320 moore1320 is offline
FRC #3496
moore1320 is an unknown quantity at this point
Single Motor Trouble
I am trying to control a single Bane Bot motor using a Jaguar speed controller.
It appears that my trouble is with the Motor Set Output VI. I tried to use the stock labview example, and still no luck. I know it isn't the electrical wiring, because this VI did not work with one of our drive motors that functions when used with the holonomic drive VI. Does anyone have any idea where I may be going worng, or what I may be over looking?
Unread 12-02-2011, 19:56
PatrickS's Avatar
PatrickS PatrickS is offline
I get my code from /dev/null
FRC #1742 (Shockwave)
PatrickS is an unknown quantity at this point
Re: Single Motor Trouble
Does it function incorrectly or just plain not function at all?
Unread 12-02-2011, 21:50
Also, please note the LEDs on the Jaguar and report their state before running, during running, etc.
Greg McKaskle
Unread 13-02-2011, 18:56
FRC #3496
It did not function at all. The Jaguar LED's were flashing yellow. I was able to get the motor to function by deleting all of the motor references and re-coding. There didn't appear to be an error in the reference names, but I can only assume that was the problem. Thank you for your help!
