Go to Post Mmmmm, First Choice day. I can already taste the latency. - ttldomination [more]
Unread 13-02-2011, 17:21
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Wiring your LED tube indicator (the illegal way)
A lot of our team has come down with a nasty cold/flu bug lately, but one of the benefits of this has been the strange "snot box" that the team collectively produced. It also happens to signal to our feeder what type of tube we would like him to deliver to our robot.
http://www.chiefdelphi.com/media/photos/36292
The snot box is wired for 12V, and each of the three indicators uses about 60mA of current. While trying to figure out how to wire the thing, we broached a few options:
1) 2 Spikes: 1 - 12V supply from the PDB via 20A breaker, 2 - relay outputs from the DSC
2) Custom circuit: 1 - 12V supply from the PDB via 20A breaker, 3 - digital outputs from the DSC
3) Solenoid Breakout (illegal): 3 - solenoid outputs from a 12V powered solenoid breakout
I'm pretty sure #3 is illegal, but I would love to be proven otherwise, because I think it's the most elegant option of the 3 above. Fundamentally the "Solenoid Breakout" is a DC Sourcing Module rated for 750mA per channel - it's not specifically made to power solenoids. The limitation is that it can't source a large amount of current.
But it does have the juice to source 60mA worth of LEDs, right?
If it does, wouldn't it be the nicest way to power the "snotbox?"
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 13-02-2011, 17:36
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: Wiring your LED tube indicator (the illegal way)
Team 1716 is using one spike to control 2 LED's to indicate the desired tube. We decided that a "White Led" for a white tube would not be the best solution as it is very difficult to see in bright lighting conditions(although with your snot box i don't know whether this would be the case or not).
This is how we will be indicating... however we do anticipate a problem if something gets disconnected and we are unable to power the LED, it will always be white. We then have a hand signal system if this goes down.
If red LED is on: Give Red tube
If blue LED is on: Give Blue tube
If no LED is on: Give white tube
On another note, we are placing a ping pong ball over our LED's to diffuse them and make them more visible, this might be a lighter solution than your "snotbox", but just a suggestion.
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 13-02-2011, 18:24
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Teams are allowed to bring non-powered analyst to feeder signaling devices with them so such a devise isn't all that necessary.
Unread 13-02-2011, 19:24
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
The robot will likely be much closer and easier to see than somebody in the opposite driver station.
Unread 13-02-2011, 19:28
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
You could wave up giant colored stick(s) in the air, everyone will see that.
Unread 13-02-2011, 19:57
McGurky's Avatar
Geek
AKA: Kyle McGurk
but when you are driving, it is much easier to spend the 10th of a second it takes to push a button than fumble for the correct colored stick and hold it up.
At least in my opinion
Unread 13-02-2011, 23:13
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
You can get away with one Spike if you want. Wire the positive side of the LED's to M+ and M-. M+ would control one LED set, M- would control another LED set.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 14-02-2011, 00:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If one positive is connected to the M+ and another positive to the M-, where do you ground them legally?
Unread 14-02-2011, 07:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
PD board, or you can piggyback on the Ground terminal on the Spike. That's legal.
Kettering Motorsports
Unread 14-02-2011, 08:05
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Once there are tubes on the top row of pegs, signs become a lot more difficult to see.
We're using three different LED patterns to indicated tubes to our Human Player. They're each wired to their own spike and use both the M+ and M- terminals. We were fortunate enough to have the weight and space for three spikes so this was the easiest solution for us - but if we did it again, we would probably use two spikes and have the LEDs ground to the PD.
-Dustin Benedict
Unread 14-02-2011, 08:06
RyanN's Avatar
RyanN
Exactly! It was the old/cheap/easy method of wiring double acting solenoids back in the IFI days before you had a true solenoid breakout board.
Controls Mentor
@rnazaretian
Previous teams:
