Go to Post Our team calls me "John Regular Neun," because John V-Neun is so spectacular! - John Neun [more]
Unread 13-02-2011, 16:34
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Set Speed
Quick Question
Is there a way to set a maximum speed for all 4 motors on our drivetrain? I was thinking motor set output, but i couldn't understand where to wire it and how to configure it. Do i have to use an encoder to set a maximum speed for the drivetrain?
Thanks
Unread 13-02-2011, 20:22
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Set Speed
What do you mean by set a maximum speed? You could just a multiply block and then a .9 to your joystick values.
Unread 13-02-2011, 20:33
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
Re: Set Speed
Maximum speed should be 1 or -1 for any motor. Try seeing if you can wire some kind of boolean value since they are always 1 or 0. That way you will have no movement or maximum speed.
