Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 12-02-2011, 22:16
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Autonomous
Where do I place the arm movement code for our autonomous? I know its in the autonomous vi but where and/or how do I place it?
Unread 13-02-2011, 00:21
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Autonomous
You use constant values in place of where you would normally wire the joystick axis
Expect the best, Prepare for the worst
Unread 13-02-2011, 14:18
Re: Autonomous
Where and how you place your arm control depends on what you want the arm to do, when you want the arm to do it, and what else is happening in autonomous.
What do you want the arm to do?
When do you want the arm to do it?
What else is happening in autonomous?
Unread 13-02-2011, 14:38
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Autonomous
Or you could use variables that vary based on how many times a loop has cycled.
I don't know labview stuff but in c++ it would look something like this.
double virtualStick;
for (int i=0; i>-1; i++)
   virtualStick=-(i-7.5)(i-7.5)+1;
   virtualStick/=2;
   virtualStick+=.5;
   //arm code here [using virtualStick in place of joystick values]
  Wait(1.0);
this particular piece of code would increase speed for the first half of autonomous, and decrease it for the second half
Unread 13-02-2011, 20:51
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
Re: Autonomous
If the autonomous code you received from FIRST followed the line and stopped after a while, try creating a sequence structure. The first frame should be around the autonomous code given while the second frame will be where your arm code will be.
