Go to Post Defense is not at all anti-GP. - Wetzel [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Unread 13-02-2011, 01:17
pacerobotics pacerobotics is offline
FRC #3629
pacerobotics will become famous soon enoughpacerobotics will become famous soon enough
Unhappy Sample code for Windriver needed (FRC)
Help Please!!!
Thanks
Unread 13-02-2011, 09:05
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: Sample code for Windriver needed (FRC)
In the workbench.
File->New->Project->Examples->VxWorks Downloadable Kernel Module Sample Project
Choose any example project that starts with "FRC".
Unread 13-02-2011, 17:56
FRC #3629
Thank you so much but it seams I don't have anything that has "FRC" in the beginning. Is there an update I have to download???? please help
Unread 13-02-2011, 19:09
FRC #3629
OK. We figured out where to get the update but all they all are for arcade drive or tank drive but we have a more complex wheel setup. We would really be amazingly better off if we could figure out how to simply receive values from several joysticks, label give the values to common variables, and know how to assign the variables to jaguars to make the motors move. It seems like a complex list but If someone could just post some code (even from yours, you can trust me I won't plagiarize) that would be great.
Unread 13-02-2011, 23:09
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
What kind of complex setup do you have? WPI library provides a lot of different drive configurations, tank drive, arcade drive, mecanum drive. You can look at the WPI source code in robotdrive.cpp (c:\WindRivier\WPILib). It shows you how they implemented all different drives. So it is your sample code if you want to write your own drive system.
Unread 17-02-2011, 00:15
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Originally Posted by pacerobotics View Post
Help Please!!!
Thanks
I've posted a complete C++ program here: http://www.chiefdelphi.com/forums/sh...11#post1024111
It incl. arcade drive, I understand you want to write your own drive code. The code shows how to read (obtain) the values from a joystick and drive a Jaguar/Victor with that value. Joysticks give a value between 1.0 and -1.0, inclusive, in the X, Y, and Z axies. (The Z axis is the throttle thing at the base of the JS.)
Victors and Jaguars accept values -1.0 <= x <= 1.0. The direction of rotation is a function of how the motor is wired and the nature of the gearbox.
The algebra in between the JS and the Jaguar is up to you :-)
Whenever you change the drive code (incl. the first version) YOU MUST TEST WITH YOUR ROBOT ON BLOCKS with the wheels off the ground. There's a real risk of the motors being powered other than as you expect and the robot smashing into an object - I've seen it happen.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
