Re: Building a claw post-ship
agreed, but the point of first is to build a robot in 6 weeks. building a robot and a lift, but not having a claw, is not a robot, it is 2/3 of a robot. i would make sure to have something on the robot, it sounds to me like you plan to simply bring your completed claw, the Manuel says "replacements or upgrades" if it is added without replacing anything then it does not fall into that category.
I could, if I wanted to, and I was able to do it in under 30 lbs, ship a box-bot, build an arm and a deployment system for it, bring both of those to the event, bolt them on, and I'm legal in terms of build time. Other rules... well, that's what inspection is for. Al, where did that note of yours come from? I don't remember seeing it in the Manual for this year. Under <R24>, I could manufacture a complete competition system in my shop if I wanted to, unless there's another rule that says otherwise. |
i don't believe that a whole arm is an upgrade so much as an addition. i think what they mean by additional functionality would be a rolling claw vs a clamping claw, or shifters vs single speeds, not a manipulator vs nothing. |
Last year the team I mentor brought in the lifting sub-system for the robot at the Hawaii regional and another team built a lifting system before their first regional.
Last year we had ~60 lbs we could keep from shipping, I do not see a difference from last year to this year for the with-holding allowance except for the amount. I see a claw upgrade, not as a subsystem upgrade, but a host-bot upgrade. <R24> During the period between ship date and the competitions, all teams may manufacture SPARE, REPLACEMENT, and UPGRADE PARTS, and develop software for their ROBOT at their home facility. Teams may continue development of any items retained under the WITHHOLDING ALLOWANCE during this period, and then bring them to the competition events <R33> Teams may bring a maximum of 30 pounds of custom FABRICATED ITEMS (SPARE PARTS, REPLACEMENT PARTS, and UPGRADE PARTS, plus all WITHHOLDING ALLOWANCE items) to each competition event to be used to repair and/or upgrade their ROBOT at the competition site. All other FABRICATED ITEMS to be used on the ROBOT during the competition shall arrive at the competition venue packed in the shipping crate or lockout bag with the ROBOT emphasis mine* Nowhere does it say that you need to be upgrading a particular subsystem such as a claw. |
Interesting debate, with valid points on both sides.
I've posted this to FIRST Q&A, so hopefully, we will know a definite answer soon enough. |
The OP says the arm already has a hook, and since a claw is merely an upgraded hook, it would follow that the claw is an upgraded part since it adds functionality to the robot. If, however, the robot were shipped sans hook, I could see a potential problem.
#7
Can you look an inspector in the eye and say that without laughing?
#8
Please don't let bureaucracy and lawyering trump the engineering...wouldn't an additional part certainly be an UPGRADE to no part at all? Upgrades provide greater performance over the previous model. Having an end effector certainly is a performance enhancer this year over not having one.
My 2 cents. |
#9
Eric,
Which note are referring to? The sentence immediately following R24 is cut and paste from the manual. The 'please note' is mine. when the manual speaks to upgrade parts I believe it is referring to your decision to beef up a part on a mechanism you designed and built prior to ship but now have second thoughts about. This also follows R24... The primary intent of this rule is to allow teams to withhold the ROBOT control system, the OPERATOR CONSOLE, and selected relevant subsystems and access them after the shipping deadline. This will allow teams to have the maximum time possible prior to each competition event to develop and complete the software for their ROBOT while maximizing the potential capabilities provided by the control system. Emphasis mine. |
#10
According to the definition of Upgrade Parts, it says COTS or Fabricated Component or Mechanism that is used to improve/add functionality, in effect. It does not say, change how part works. It does not say, you have to have had that part built/on the robot before ship. It says, add or improve functionality. As such, anything saying "it has to have been on the robot before ship" or "the robot has to have similar functionality already" goes against the Manual's wording. I agree that the intent is to upgrade individual parts--but there is nothing to prevent an entire arm that never saw the robot before ship from coming in as part of the Withholding Allowance or as COTS parts or both and being bolted together at the event. I would, however, apply the general Manual caution against "lawyering" the rules to allow/disallow bringing in any given item. <R25> refers to at-event work, not Withholding Allowance work. |
#11
Eric,
I am reading R23 and R24 together. Please also read the blue highlight under UPGRADE PARTS for an explanation. I do not believe it is the intent of the GDC to allow you to continue with building robot subsystems and bring these completed subsystems to a competition if they are less than 30 lbs. I do believe that the GDC has agreed that a team may design and redesign anything for the robot after ship. A team may also build one of these designs between ship and events. The team may not bring that system to a competition in an assembled form. They may bring parts and materials that can be assembled at the event. In my mind, that is an attempt to give teams the same advantage for building. |
#12
If it has the ability to increase robot performance without the risk of compromising the current solution. DO IT!
#13
Last year our team withheld our entire kicker and it turned out to be one of the best decision we made, not that we had much choice since it barely worked on ship day. All I have to say is make sure you have a plan set in stone for when you get to your regional, know exactly how and when you are going to put it together before you get there. We luckily knew exactly what we were going to do and were fairly successful with our new kicker.
I would also suggest keeping your current design in working order in case things don't work out. |
#14
It is not the intent of the GDC. I agree with you on that, Al.
Stop work on the robot and ship it at or before the deadline; you have all the calendar time in the build season. Design and fabricate everything. Quote:
The intent is, don't bring in brand-new stuff (arm, deployment system, etc.) that was built after ship. The problem is, it is not prohibited to do so. So, if I were to build a brand-new, not-designed-during-build arm, claw, deployment system, electronics box, or other similar item, that fit into the <R33> allowance, but was built after ship, I can't be stopped under the current version of the Manual, unless it's over the weight of the allowance (and I can probably take it apart to get into that if I need to). Intent of the GDC can't stop anything unless it's in the Manual as a rule, and while it is expressed, it isn't a rule. I think we're starting to get over into something like the "What is a robot" debate from 2008, so I'll stop there, with the note that I would expect a slightly clearer "intent note" in the Manual next year. |
#15
I would like one of the previous posters to ask this on the Q&A. It will make someone's life simpler.
