Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Unread 14-02-2011, 12:10
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
pr0ph3t is an unknown quantity at this point
mecanum wheels at 45 degrees
I was wondering, does anyone know if it's possible to mount mecanum wheels at 45 degree angles in the corners of the robot (like you would omni wheels) and achieve forward/backward/strafe/spin motions?
Unread 14-02-2011, 12:14
Joining the 900 Meme Team
FRC #0079
Re: mecanum wheels at 45 degrees
Possible: Yes.
Useful: No, Mecanums can already achieve those motions as they are (in a very simple sense) omni wheels mounted at a 45 already.
I suggest, if you are still not sure about your drive train that you pull out the KoP frame and put the KoP drive train together since you only have 1 week left.
Unread 14-02-2011, 12:18
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Mecanum wheels generate a force at 45 degrees to their axis of rotation. Mounting them at 45 degree angles will add or subtract from this, depending on how you do it, creating either a 0 degree or 90 degree vector. In other words, tank drive! The resultant drivetrain would behave like tank drive, except be harder to build, have low traction, and suffer frictional losses from the mecanum rollers. Not exactly desirable...
Unread 14-02-2011, 13:12
Well, if you swapped the rear left and rear right wheels, and then mounted all 4 wheels at 45 degrees, you'd have a rear-wheel-drive front-wheel-steering vehicle (with lots of frictional losses and poor traction).
Unread 14-02-2011, 13:28
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
If you have a frame with wheel mounts at 90 degrees to each other (45 degrees from normal), you could use regular omni wheels:
(http://www.andymark.com/ProductDetai...ctCode=am-0013)
Mecanum wheels in that configuration would not be omnidirectional. Rotating the front right and back left wheels 15 degrees counterclockwise and the front left and back right wheels 15 degrees clockwise would provide more power in the forwards direction (I think) while retaining some omnidirectional ability.
Unread 14-02-2011, 13:34
If the reference from which you are rotating the wheels in the above is the normal mecanum orientation, then you have the clockwise/counterclockwise swapped.
Unread 15-02-2011, 11:51
AKA: Jeff Ousley
FRC #3528 (Up Next)
Thank you, everyone, you've been most helpful.
Unread 15-02-2011, 11:59
Oops, I was mixing up my force vectors.
