Go to Post Can anyone tell that it is 5:20 in the morning and I can't sleep? Thanks, Dave. - ChuckDickerson [more]
Unread 14-02-2011, 12:44
Re: Arcade Drive in Autonomous mode and Tank Drive in Teleop mode?
Simple answer: yes.
The number of motors is actually set in Begin when the drive motors are opened. The default project uses Open 2 Motor Drive. You can replace that with Open 4 Motor Drive.
Once you've done that, any of the drive functions will control it appropriately. Arcade Drive and Tank Drive do exactly what they should. (If you've built a holonomic drivebase with mecanum or angled omniwheels, Holonomic Drive will work too.)
