Go to Post If the GDC doesn't want better teams to strap components on to other robots, they should design a game that doesn't require better teams to strap components on to other robots to win. - Tom Bottiglieri [more]
Unread 14-02-2011, 13:26
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Autonomous vi.
So I made an autonomous program but not sure where to put it in the main vi.
Any help would be greatly appreciated.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 14-02-2011, 13:32
Re: Autonomous vi.
Autonomous code goes in the Autonomous Independent vi.
You shouldn't be changing anything in Robot Main.
Unread 14-02-2011, 14:00
Slothbron's Avatar
AKA: Nathan
Re: Autonomous vi.
Ok but when you open the Auto Vi There is a pre made code we dont want there run code but want to utilize the the line following code.
MRT 3216
Unread 14-02-2011, 14:09
Re: Autonomous vi.
The default Autonomous Independent is the line following code. You can delete it all and replace it with whatever you want.
Unread 14-02-2011, 14:23
Slothbron's Avatar
AKA: Nathan
Re: Autonomous vi.
Ok but I dont have to delete it right? I can put this new code in there with it and it with work fine?
MRT 3216
Unread 14-02-2011, 14:34
Re: Autonomous vi.
At least wrap a Diagram Disable structure around the code you aren't currently using, otherwise, it will mess up your code that you do want running.
If you want to integrate them so it all works together, then that's fine too, but disable the default autonomous until you're sure that yours works correctly.
Unread 14-02-2011, 14:48
Slothbron's Avatar
AKA: Nathan
Re: Autonomous vi.
ok i will give this a try thanks.
MRT 3216
