Go to Post In engineering, it's important to use the appropriate tools and not more resources than are required. - AdamHeard [more]
Unread 14-02-2011, 13:57
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Encoders in Auto Mode
No, you must call SetDistancePerPulse for all four encoders after they are instantiated (as part of the encoder initialization). The parameter to SetDistancePerPulse must be calculated or experimented. Basically, one revolution of the encoder will give you x pulses (I forgot what the KOP encoder is, probably 1440 pulses per revolution), then you have to multiply with the gear ratio if the encoders are mounted on the motor side instead of the wheel side.
Do this in your encoder intiialization:
distancePerPulse = (wheel_diameter*PI/pulses_per_revolution)*gear_ratio;
leftfrontEncoder->SetDistancePerPulse(distancePerPulse);
leftrearEncoder->SetDistancePerPulse(distancePerPulse);
rightfrontEncoder->SetDistancePerPulse(distancePerPulse);
rightrearEncoder->SetDistancePerPulse(distnacePerPulse);
Then do this in your autonomous loop:
double distanceTraveled = (leftfrontEncoder->GetDistance() +
                                     rightFrontEncoder->GetDistance() +
                                     leftRearEncoder->GetDistance() +
                                     rightRearEncoder->GetDistance())/4.0;
if (distanceTraveled < 60.0)
    MecaumDrive_Polar(forwardPower, 0.0, 0.0);
else
   MecaumDrive_Polar(0.0, 0.0, 0.0);
Unread 14-02-2011, 13:59
mikets's Avatar
Software Engineer
You might the discussion of forward kinematics on Pages 7,8,&9 of this paper of interest.
Thanks Ether, I will read it.
Unread 14-02-2011, 14:07
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
else
so this funtion will make the robot drive until it goes 60 inches.
my question is isnt there any easier way of doing it because you can fine the distance traveled by using the .getdistance in telop mode. why cant you just say something like
myrobot.drive till encoder turn so many revolutions?
Unread 14-02-2011, 14:56
mikets's Avatar
Software Engineer
That's basically what the code is doing: drive until the encoder->GetDistance() say it has traveled 60 inches.
You could put the code in a function like this:
void DriveDistance(float targetDistance)
    float distanceTraveled = (leftfrontEncoder->GetDistance() +
    while (distanceTraveled < targetDistance)
        MecanumDrive_Polar(forwardPower, 0.0, 0.0);
    MecanumDrivePolar(0.0, 0.0, 0.0);
But this function is blocking. You cannot do anything else why the while loop is waiting. Not to mention this will starve your watchdog although by calling the MecanumDrive_Polar function, you probably will feed the per motor watchdog for this year's WPI library. So it's better to do what I suggested in the previous post of checking the target distance in your autonomous loop.
Unread 14-02-2011, 15:23
so the best and easiest way is the way you described in post 16
else
Unread 14-02-2011, 15:24
mikets's Avatar
Software Engineer
Yep, unless you have some other restriction/requirements.
Unread 14-02-2011, 15:27
ok i will try that thanks for the help
if i need more i will send you a message or put another post here
