Go to Post Pictures are worth a thousand words... cell phone pics are worth 750. - kramarczyk [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 05-11-2002, 22:49
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Take the AGP one out, then the error will probably clear up so you can configure it. It probably just is a problem of it not being the Primary Display Adaptor.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 05-11-2002, 22:59
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
I got the idea you can configure a card being the Primary one only when Windows recognizes there are two cards there.
Likewise, shouldn't this have not mattered when I put two PCI cards in and gotten the same results even when I swapped the PCI slots?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 06-11-2002, 00:13
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
ohhh....
Does Windows 2k support monochrome monitors?
/me goes looking
Wetzel
Repeater
Unread 06-11-2002, 00:33
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
How old is your mobo? My primary desktop has a very similar setup to yours:
Primary: GeForce256 DDR AGP
Secondary: Matrox G200
In your BIOS, you should have some option as to whether to use AGP or PCI as your primary video card. Try changing this and seeing what happens.
Unread 06-11-2002, 10:01
Some video cards just don't have the ability to run as a secondary card. The Jaton (trident) card that I bought a month or two ago to do this, will not work as an secondary card.
Your best bet is to wait on hold 30 minutes with tech support, because that 30 minutes is less time then you will spend messing with it ;-)
Unread 10-11-2002, 17:15
Matt VP's Avatar
Matt VP Matt VP is offline
#0074 (Hot Heads)
Matt VP is an unknown quantity at this point
I'm running dual monitors right now. Of course, I'm using the nView on my Geforce4 ti4200. Set it up in about 20 seconds.
You can't call that GF256 a quadro unless you can hook up more than one monitor to it.
Matt VanderPloeg
AMD Fanboy From Hell
Team 74
Unread 10-11-2002, 18:21
Crusty Mentor
FRC #0097
Well, you see, therein lies the problem. Some of us don't have $300 uber-top-of-the-line cards with 2 digital outputs AND, as if that wasn't enough, a tv output too. Some of us are stuck with oldskewl equipment that requires we add in a second card to get a second monitor. Some of us don't have money to spend on a card that just got out of governement research labs - we 'upgrade' not through green pieces of paper, but through a soldering iron! But then again, some of us also wish they had some steady source of income so we COULD get all of the above-mentioned items.
Dan L
Team 97 Mentor
Unread 13-11-2002, 19:44
Matt VP's Avatar
#0074 (Hot Heads)
We could build a quadro, just it would cost more than what a fully assembled quadro would
Matt VanderPloeg
Team 74
Unread 19-11-2002, 16:01
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
BIOS
There is usually a setting in the BIOS setup that specifies which card is primary. Look in the BIOS. If it's not there, perhaps you should flash the BIOS with the latest version. Maybe an old BIOS is the root of the problem.
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
[white paper] Dual Motor Gear Switching Assy Brandon Martus Motors 0 29-06-2001 12:56
