Go to Post Angry Teams will not get the field going any quicker trust me on that! - mtaman02 [more]
Unread 13-02-2011, 21:58
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Unhappy CIM motor fun
yesterday we test our driving with a xbox 360 controller. it worked fine except for one thing. One of the motors is moving, what we think, twice the speed of the others. We have changed the pwms and double check the connection to the jaguars. Could it be the code????
Unread 13-02-2011, 22:07
Re: CIM motor fun
For reference here is our Telop code
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		en1.Reset();
		gyro.Reset();
		AxisCamera &robocam = AxisCamera::GetInstance();
		robocam.WriteResolution((AxisCamera::Resolution_t)3);
		robocam.WriteBrightness(0);
		Wait(3.0);
		while (IsOperatorControl())
		// read digital inputs
		unsigned short leftValue = left->Get() ? 4 : 0;	// read the line tracking sensors
		unsigned short middleValue = middle->Get() ? 2 : 0;
		unsigned short rightValue = right->Get() ? 1 : 0;
		//Look for line sensor inputs only when  right bumber is pressed
		if (xbox.GetRightBumper()){
			switch(leftValue + middleValue + rightValue){
			case(0x0): // normal operation
			case(0x5):
			case(0x7):{
					//printf("no line found \n");
					//void MecanumDrive_Cartesian(float x, float rotation, float y, float gyroAngle = 0.0);
					if (!xbox.GetLeftBumper()){
						myRobot.MecanumDrive_Cartesian(xbox.GetLeftX(), xbox.GetRightY(), -xbox.GetLeftY(), 0); //Mecanum drive at full speed
					else{
						myRobot.MecanumDrive_Cartesian(xbox.GetLeftX()/2, xbox.GetRightY()/2, -xbox.GetLeftY()/2, 0);//Mecanumdrive at half speed
					break;
			case(0x1):	// straif right
			case(0x3):{
					// printf("right leftstickX = %f, abs = %i\n",leftstick.GetX(), abs((int)leftstick.GetX()));
					float leftvalue = (fabs(xbox.GetLeftX())/-2);
					//printf("right leftstickX = %f\n", leftvalue);
					myRobot.MecanumDrive_Cartesian(leftvalue, 0, -xbox.GetLeftX(), 0);
					break;
			case(0x2):{ // keep going
					//printf("middle \n");
					myRobot.MecanumDrive_Cartesian(0, 0, -xbox.GetLeftX(), 0);
					break;
			case(0x4): // straif left
			case(0x6):{
					//printf("left \n");
					float rightvalue = (fabs(xbox.GetLeftX())/2);
					//printf("left leftstickX = %f\n", rightvalue);
					myRobot.MecanumDrive_Cartesian(rightvalue, 0, -xbox.GetLeftX(), 0);
					break;
			default:
					break;
		else {
			//This is how the robot will drive if the right bumper is not pressed
				myRobot.MecanumDrive_Cartesian(-xbox.GetLeftX(), -xbox.GetRightY(), -xbox.GetLeftY(), 0); //Mecanum drive at full speed
			else{
				myRobot.MecanumDrive_Cartesian(-xbox.GetLeftX()/2, -xbox.GetRightY()/2, -xbox.GetLeftY()/2, 0);//Mecanumdrive at half speed
Unread 14-02-2011, 15:28
Re: CIM motor fun
Anyone know what the problem is cause we cant figure it out and its getting frustrating...
Unread 14-02-2011, 21:20
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: CIM motor fun
You did not describe too much detail on what the problem was. For example, under what condition when the problem occurred (i.e. which button did you push or what were the joystick positions, basically which code path it took)? Which motor is moving twice the speed as the others? What happens if you move the joysticks? I don't quite understand your code. While it is teleop code, you are reading the light sensors to follow the line but yet you are also reading the joysticks too? Are you doing some sort of assisted drive? If you want somebody to comment, you need to give more details on what you are trying to do and what are the symptoms.
Unread 14-02-2011, 21:22
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Re: CIM motor fun
Not an expert by any means, but hopefully someone will come along that can help more. In the meantime, have you tried calibrating the jaguars? They should be pre-calibrated, but it's worth a shot if you have nothing else to try.
Unread 14-02-2011, 23:28
Re: CIM motor fun
We got it
Unread 17-02-2011, 02:09
FRC #2605
Re: CIM motor fun
Just curious. What was the problem and solution?
Unread 17-02-2011, 07:00
Re: CIM motor fun
We had to recalivrate them
