Go to Post Heck, I gave several [E-Saver Lightbulbs] away as Christmas presents... - DonRotolo [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 02-14-2011, 03:53 PM
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: Can't enumerate the entire bus
So I just reflashed two jags individually and reassigned the IDs to them and still no luck. Even if both are hooked up hitting assign does not make them both flash green, only the first one meaning that even broadcasting does not reach the second one in the chain. I'm out of ideas so I'm really hoping for some magic fix from you guys.
Oliver
Unread 02-14-2011, 07:43 PM
AKA: Oliver Graff
FRC #3780
WE GOT IT WORKING!!!!!
Okay now that I'm done with the excitement outburst I will let you all know how. Turns out the issue was the impedence (as many people said). The problem exactly was our 100ohm resistors were not enough for a terminator plug. Instead we are using 680ohm resistors on both ends of the bus. That worked for 2 Jags and we are seeing if it will work with more.
Unread 02-15-2011, 08:29 AM
AKA: Oliver Graff
FRC #3780
Actually it's not working quite as well as it seemed. It can't do more than two and it seems to fail on longer wires. . Oh well looks like PWM for this year and I'll try to figure out CAN on off season,
Unread 02-15-2011, 08:36 PM
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You say the 680 ohm resistors worked as termination when the 100 ohm didn't?
I would double-check the cabling. Are they all straight-through?
-- Marshal Horn
Unread 02-16-2011, 11:17 AM
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Oliver
This sounds to me like you made a cross over cable instead of a strait through cable. The middle two wires must not be switched!
