Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
Unread 14-02-2011, 15:53
stormyweathers stormyweathers is offline
FRC #3653
stormyweathers is an unknown quantity at this point
adding controls to the dashboard
When tuning the autonomous code, it gets excessively inefficient to have to rebuild and redeploy the code when tweaking scaling factors.
is there a way I can add a control onto the dashboard that can alter a defined variable on the fly?
Unread 14-02-2011, 16:30
Re: adding controls to the dashboard
You don't have to build and deploy the code every time. When you're doing development, you can just "run" the Robot Main vi. If you do that, you have the vi front panels available to you on your development computer. Make your scaling factors LabVIEW controls and you'll be able to tweak them as much as you want while the program is running.
When you have the values you want, you can either replace the controls with constants or use the controls' popup menu to set the current value as the default.
Unread 15-02-2011, 11:40
FRC #3653
i've tried doing that, but I cant actually control the robot that way.
how do I enable the robot if I just run main.vi?
the driverstation doesn't pop up
Unread 15-02-2011, 12:32
Just run the FRC Driver Station application. It doesn't start by default when you log in as the Developer user.
