Go to Post There's no finer engineering than pit engineering. - kaszeta [more]
Unread 14-02-2011, 16:04
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: illegal
Originally Posted by big1boom View Post
4 BaneBots motors, any combination of the 4 allowed models.
There are actually 6 legal Banebot motors, The M7-RS775-12, M7-RS775-18, M5-RS550-12, M5-RS550-12-B, M5-RS540-12, and M3-RS395-12.
The two not originally included in the KOP were the RS775-12 (Physically Identical to the RS775-12, but designed to run on 12 volts, less robust and less powerful than an RS775-18 running at 12V) and the RS550-12-B (Functionally and Physically Identical to the RS550-12, but has a longer shaft on back of motor to facilitate encoder mounting.)
You can use any 4 motor combination of the 6 legal motors.
-Dustin Benedict
Unread 14-02-2011, 19:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: illegal
Nobody remembers the Belimo torque motor?
Unread 14-02-2011, 20:07
Re: illegal
Also, there were actually a couple different drill motors. In 2000, 2001 and 2002, there was a Johnson drill motor (roughly RS-775-sized, I believe). Then came the more powerful Bosch/Scintilla drill motor from 2003 to 2004.
There were also several versions of the window motor. In particular, there were both left- and right-hand versions of the Denso, Nippon Denso and a number of externally-similar Keyang window motors. I don't think Tiagene made any, but I could be wrong.
There were several different van door motors, from Bosch and Tiagene (they look like window motors, but are bigger).
Unread 14-02-2011, 20:34
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: illegal
We still have that laying around actually.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
