Go to Post Well, I think it's awesome and the best thing ever. But I'm biased. ;) - OldDan1168 [more]
Unread 14-02-2011, 14:39
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
pic: Robot is coming together....
Unread 14-02-2011, 14:41
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: Robot is coming together....
looks similar to ours, out of curiosity why the circle pockets? we always use triangles but never really thought about why.
Unread 14-02-2011, 14:50
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
I would assume it's for ease of manufacturing. Taking an aluminum tube to a mill and cutting out a row of circles is a fairly simple procedure.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 14-02-2011, 14:58
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
With limited CNC time our team uses circles. In addition with properly spaced out circles we could also put in several mount holes without disturbing the circular pattern.
I have never really been a fan of a lot of the triangles because most teams end up doing triangles that contain a lot of zero force members. Done right the truss looks great and performs well though.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 14-02-2011, 16:47
Bob Steele's Avatar
AKA: Bob Steele
if your intent is to lighten... then it makes no difference... if your intent is to make a structure with the minimum weight and a definable way of transfering energy (either from gravity or collision or something else..) then triangles are the way to go.
Both look good... but circles waste material when it comes to the transfer of energy (think straight lines...) Our design this year utilizes triangles to distribute the energy of a high speed collision through the entire robot... always putting our rivets in shear and not in tension along with putting our sheet aluminum in compression only.
R
Unread 14-02-2011, 16:49
Garret's Avatar
AKA: Garret Smalley
We used circular holes to lighten the beam for the ease of manufacturing. Our team does not have a mill, all milling (which is generally very little) is done by our sponsors. Those beams were made by our team members who manually did it on a drill press.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 14-02-2011, 17:17
J_Miles's Avatar
J_Miles J_Miles is offline
FiM Referee
AKA: Jared Miles
no team (EngiNERDs)
J_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to behold
Originally Posted by Bob Steele View Post
If your intent is to make a structure with the minimum weight and a definable way of transfering energy (either from gravity or collision or something else..) then triangles are the way to go.
For sure. Generally when we lighten our robot, we arbitrarily take out material in areas of low stress, but when we want to eliminate serious amounts of material and retain a LOT of strength, we have some of our more mathematically-inclined students and our resident structural engineer go to work. For example, our lifter from last year had to be strong enough to support 450 pounds of load (which it never used, sadly), yet still needed to be strong, so we did all of the stress analysis and turned the main support member into a truss, which I guess is two adjacent triangles.
Unread 14-02-2011, 23:26
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
As an old-time robot inspector, I think you need to check the bumper rules. It doesn't look to me as if your numbers meet the 3/4 in. stroke requiremtent. Hate to be the bearer of bad news, but though you might want to know before you hit your first regional!
