Go to Post You can admire machines, but you don't really love them... This program has enabled me to make a difference that I believe is good for the future of humans on this planet. - MooreteP [more]
Unread 12-02-2011, 13:15
Nicandy's Avatar
Nicandy Nicandy is offline
AKA: Nicole/Andy
FRC #3580 (Marinerds)
Nicandy is an unknown quantity at this point
Help With Photoswitch Wiring (Rookie Team)
From other threads and the wiring diagram, we've been able to figure out where all of the wires are supposed to go... But how do we connect the white sensor with to the I/0 on the digital side car? Do we need to add a Wago connector or something of the sort? Any help would be greatly appreciated. <
Unread 12-02-2011, 13:27
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
Re: Help With Photoswitch Wiring (Rookie Team)
You can use one of the PWM cables (white, black, red wires with the black female connector). You only need to attach the signal wire (white) to the signal wire you are using from the sensor.
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 14-02-2011, 17:19
Nicandy's Avatar
AKA: Nicole/Andy
I think I get it! Thank you, I'll try that and see what happens!!
Unread 14-02-2011, 17:25
Nicandy's Avatar
AKA: Nicole/Andy
Just one thing... To do that we need to cut off the male side, correct? Does that comply with the rule that states that you can't modify anything in the KOP?
