Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
Unread 14-02-2011, 17:25
cRIOandMilk cRIOandMilk is offline
FRC #0649
cRIOandMilk is an unknown quantity at this point
Re: pic: Just a few parts left
Hey, we just need to know what breaker to use with the bane bot motors. bros. thanks - 649
Unread 14-02-2011, 18:13
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Originally Posted by kramarczyk View Post
Great stuff guys. Would you mind sharing the ratios you found in those drills? Some of the folks that are having difficulty getting BB gearboxes might appreciate it.
The Black and Decker screwdriver has about an 80:1 reduction. Ones designed for lower voltage will probably have less reduction.
The RS395 stalls at 15A so there is no reason to use anything greater than the 20A breaker, which will allow you to use smaller wire.
Jason
