Go to Post You know you're addicted to FIRST when you text your mentors more than your friends from school. - LindsayC [more]
Unread 14-02-2011, 19:13
Team 1339
Posts: n/a
Minibot Deployment Time
Do we have only 10 seconds to deploy the minibot and have it climb the pole? or do we have 10 seconds for deployment and then another 10 seconds for it to climb the pole?
Unread 14-02-2011, 19:28
Re: Minibot Deployment Time
You may deploy with 10 seconds or less left in the match. After the match ends (time hits zero or all 4 towers trigger), the 10-second "come to rest" countdown begins. If a Minibot triggers the target within that "come to rest" period, it will count.
Unread 14-02-2011, 19:36
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
10 seconds for everything: this means you must deploy and climb within this time.
See the text block after <G02>, rules <G17> through <G35>, and Section 3.1.5.
<G17> in particular does not allow you to deploy a minibot before the END GAME.
The END GAME is the:
10 seconds before the end of the MATCH, when HOSTBOTS may DEPLOY their MINIBOT without penalty
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
