Go to Post P.S. Who doesn't have CD as there homepage! (I mean, come on people. It's not like there's anything else to do on the net... :)) - Ryan M. [more]
Unread 12-02-2011, 18:29
elmer_fud elmer_fud is offline
mentor/code monkey
FRC #2859
elmer_fud is an unknown quantity at this point
Differn't Cypress I/O usage
Is it possible to use a different Cypress I/O module than the one supplied in the kit of parts. I messed up and ordered the PSOC 5 board (same layout except black instead of blue) and our computer will see it but we can not load the First program on to it.
One I ordered
http://www.cypress.com/?rID=43674
One that comes with the KOP
http://www.cypress.com/?rID=38235
Thanks,
Unread 13-02-2011, 07:23
Re: Differn't Cypress I/O usage
I don't think the rules prohibit it, but that doesn't mean it will work with the DS as a drop-in replacement.
I'd think your options are to see if they will swap for the correct one, or see if you can program it using the hex file. I suspect the hex for one model will not work for the others. If you do get it to work, please post how.
Greg McKaskle
Unread 13-02-2011, 08:01
You would have to recompile the FIRST source for the new target.
There was a thread where other people mentioned having the same problem.
Unread 14-02-2011, 20:45
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
I downloaded the source but get this error when I try to open either the workspace or project file:
Error: prj.M0052: Unable to open the project "": (Unexpected xml node type encountered: Element, expected: EndElement). Address the error and try again.
I tried downloading a new copy, but the same thing happens. Ideas?
Which badges can you claim?
Unread 15-02-2011, 23:09
mentor/code monkey
FRC #2859
I looked at the source code and the PSOC programmer. I think I can use the PSOC 5 but I will lose some functionality. I was able to compile it and download it to the PSOC though.
Unread 15-02-2011, 23:11
mentor/code monkey
FRC #2859
I should add the only thing I did was update the psoc creator and change the device by project>> device selector
Unread 17-02-2011, 19:18
Redneck's Avatar
Hacker Hick
FRC #0599 (Robodox)
Solved my own problem - just had to update the Cypress software.
