Go to Post By the way, safety glasses are so in style now, :) - LightWaves1636 [more]
Unread 14-02-2011, 22:44
RoboGuy RoboGuy is offline
FRC #3452 (GreengineerZ)
RoboGuy is on a distinguished road
Servos not working?
I've been trying to program the servos for the Axis camera to move, but even when I am sending a pwm signal to them they don't move. The dashboard indicates that I am sending a signal and I even checked the end of the pwm cable with a voltmeter and got a reading. Is anyone else having this issue?
Unread 14-02-2011, 23:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Servos not working?
Did you check for the Jumpers on the Digital Sidecar? You need it to put it into the 2 pin slot next to the channels you are using for servos.
Unread 14-02-2011, 23:51
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
if you don't have jumpers, wire and electrical tape will do the trick
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 15-02-2011, 14:57
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
This is $.99 http://www.radioshack.com/product/in...ductId=2103807
If that is the problem, I would highly suggest buying jumpers. Although we do get them in the KOP.
Unread 15-02-2011, 15:31
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Try running the servos off a RC airplane controller/reciever or another conrtrol system to see if it's the servos or some other problem.
Unread 15-02-2011, 22:19
Yeah it was the jumpers. This was my first time working with servos so I didn't know that jumpers were needed. Thanks for the info!
Unread 16-02-2011, 00:35
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Yea, don't worry, I was on the same boat last year LOL
