Go to Post - Just because you can buy 50 giant pixie stix with your roommates Sam's club membership does not mean you should eat them all at once. - Not2B [more]
Unread 14-02-2011, 13:07
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
Crosspost: Tethered operation unsuccessful... =(
Our team is trying to go through the basic motor control tutorial, but can't get our motors to work. We're stuck at the simple motor control vi deployment.
1. Our program is correct, afaik.
2. The code pushes down to the cRIO successfully.
3. The LEDs on the cRIO are all on.
4. The digital sidecar's LEDs are all green.
5. The Jaguar continues to flash yellow/orange.
6. The motor does not move.
Any advice? Is our sidecar dead? I'm pretty sure our cRIO is working fine as when we log into driver station it indicates there's communication and also the VI deploys onto the cRIO fine.
Unread 14-02-2011, 13:25
Re: Crosspost: Tethered operation unsuccessful... =(
Really? Some of them shouldn't be.
Did you use the Driver Station to ENABLE the robot? Is the PWM cable securely plugged in, at both ends, in the correct orientation?
Unread 14-02-2011, 13:52
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Make sure the PWM cables are correctly plug in. I think white face the inside of the side car and on the speed controls it is labeled above the the PWM slot. But don't quote me on this if it is exactly right. Also you have to enable the code in the driver station before anything will run.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 14-02-2011, 23:03
Coach/Mentor
AKA: Michael Liang
Thanks a bunch! We got it fixed. =)
Unread 15-02-2011, 08:33
Any chance you could tell us what was wrong? Someone else searching for information on the same symptoms might find it useful.
