Go to Post Pulling off an off season during a hurricane isn't easy. - Arefin Bari [more]
Unread 14-02-2011, 13:07
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
1208 Autonomous practice
Teleop - Check
Autonomous - Check:
http://www.youtube.com/watch?v=lLyJs..._order&list=UL
Minibot Deployment - Not yet
Unread 14-02-2011, 23:22
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: 1208 Autonomous practice
Originally Posted by EOC View Post
Teleop - Check
Autonomous - Check:
Just to follow up: This completes in 12 seconds and scored 7 out of 7 times. Now the programming team is working on being able to score on the non-middle pegs.
Unread 14-02-2011, 23:31
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Looking good! cant wait to see you guys in KC
Jon
Expect the best, Prepare for the worst
Unread 15-02-2011, 06:08
goffchris goffchris is offline
FRC #1884
goffchris is an unknown quantity at this point
Looks great. Are you line following? Did you set to a particular height, or are you using encoders, limit switches, etc. to get to the right height? We are trying to use encoders to make precise pre-selected height adjustments, and the lines to guide us in. We have not been able to make the camera work so far...
Unread 15-02-2011, 08:21
DavidGitz's Avatar
We are using the line sensors. Originally we were using PID control with encoders and limit switches but we were having problems on Saturday, as referenced here: http://www.chiefdelphi.com/forums/sh...78#post1023378
So we went to just running each linkage for a certain period of time and that is working very consistently, thanks to the window motors backlash. We are using 4 window motors (2L and 2R), 2 for our arm joint, 1 for our wrist joint and 1 for the winch that opens/closes the gripper. If we had chosen to use any other motor for any of these motions this might not have worked. The backlash saved us
We were planning on using the camera and had gone through some pretty extensive testing with our vision processing but we realized that with our gripper design there would be no way to see the peg cap with a tube on board where it would definitely help. We could see the peg cap from the robot frame with the camera, but in order for it to be a viable solution it had to be on our arm. So instead we mounted our camera in reverse to aid with alignment of the minibot tower.
Unread 18-02-2011, 17:59
yogiyogi yogiyogi is offline
FRC #2679
yogiyogi is an unknown quantity at this point
any chance you can post the line tracking code?
anyway, cool robot!
