Re: Effective way to rank minibots?
11-12 matches ![]() But anyway, I think placing is going to be worth just about as much as an estimation. Both will be somewhat off, but I think placing will work just as well with all minibots, whereas estimation won't work as well with the fastest (but perhaps better with the worst). |
Thus, I think it is important to rank the lower end minibots, which may range from 8-14 seconds. That time difference is probably more significance. |
You might also want to keep track of rule violations which cause the TOWER to be disabled. A 2.7-second MINIBOT isn't of much value if they try to squeak it to 2.3 seconds by DEPLOYING too early, earning a disablement.
I'd say the best way to scout minibots would be for the scouter to write down the time on the timer when the minibot hits the top. That way, it's totally objective and doesn't depend on the other minibots/what place this particular one got in the minibot race
By far the best way in my opinion is to write down the time on the clock when the minibot reaches the top. This factors in everything - deployment speed, minibot speed, whether or not teams get to the tower early enough.
My ideal mental system?
Climb percentage success, then average the successful times. Optionally, set a non-finish time at 5 secs more than the regional's slowest time. |
#7
We may have to steal this. One downside to this is if a team knows the other opponent doesn't have a minibot and thus places a final tube before deploying at the last second.
#8
If you're guaranteed first place, and you go to hang a tube.. Well, I don't like that strategy. It's thirty points! Make sure you get it!
#9
That's a cool bro way to rank it.
#10
All you would have to do is keep track of where the minibot places, and the number of points scored, the one with the most points is usually the most beneficial, and how fast they make it to the top
#11
This doesn't actually tell you anything other than relative score. It's analogous to looking at a team's average score to figure out if they're a good pick for your alliance. It gives you a general picture of what ballpark they are in, but it doesn't actually tell you how good they are, only that their opponents were better or worse.
#12
Teams with the fastest minibots, or at least those who understand their worth in the game will be prepared for deployment at least 5 seconds prior to the end game. Once the towers go live at 10 seconds they should start deployment. From there, I'd imagine the fastest minibots will reach the top at 8 seconds or so with other minibots being slower from there. |
