Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 15-02-2011, 00:43
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Photoelectric sensor wiring
Our photoelectric sensors don't work. The lights light up, and change when something is moved underneath the sensors, but they don't send signal, to track the line. Right now we have them wired so that brown and blue are power from the PDB, and white is plugged in to the DSC, and black is plugged in to nothing. Where should white be plugged in on the Digital I/O of the DSC, pin 1, 2, or 3? Is this wired correctly?
Unread 15-02-2011, 01:06
gcschmit's Avatar
gcschmit gcschmit is offline
AKA: Geoff Schmit
FRC #3061 (Huskie Robotics)
gcschmit is an unknown quantity at this point
Re: Photoelectric sensor wiring
The white wire needs to be connected to the signal pin (farthest from the edge of the DSC) on a digitial channel on the DSC. I'm not sure how you are testing if a signal is being sent or not. If you are using the sample line following code in LabVIEW, I think you may also need to open the DIO channel and store its refnum in Begin.vi.
Unread 15-02-2011, 01:22
AKA: Ty
We aren't using Labview. We're using C++. How should we be testing to see if they are sending signal back?
Unread 15-02-2011, 02:05
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
Not quite sure about Windriver this year because we are using Java, but it should be similar.
Does Windriver have a LineTrackerProject sample like Java does? If so, it may be good to review that code.
Below is the code using Java, which should be very similar to C++:
 DigitalInput left; // initializes digital input for line tracking sensors (be sure to include DigitalInput library)
 left = new DigitalInput(1);  //assigns the signal based on the port you use
//in auto or teleop:
 System.out.println(left.get());//in windriver, you would probably use cout or printf, but the left.get() should give you true or false.
//this should print to the console and be sure this is in some loop or you will only get it once (or use iterative template)
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 15-02-2011, 06:41
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
For wiring the light sensors, please refer to this thread.
http://www.chiefdelphi.com/forums/sh...ad.php?t=88548
Unread 15-02-2011, 06:57
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
To test whether your sensors are working, you can add a printf statement to your code regarding your sensors and download it to the robot. Then on windriver, open up target console (I think) and enable the robot, wave the sensors over something that makes the sensor lights go orange and yellow, or green. If the target console reads a value of 1 or zero- green then its wired correctly
Unread 15-02-2011, 08:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Your wiring appears to be correct.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 15-02-2011, 20:37
ATH1RSTYM00SE's Avatar
ATH1RSTYM00SE ATH1RSTYM00SE is offline
Stephen Fastow
AKA: Stephen Fastow
FRC #5254
ATH1RSTYM00SE is on a distinguished road
Sorry, im new to chief delphi and can't exactly find what forum im looking for but do any teams from new jersey, preferably northern have an extra pair of light sensors that we can have? We need to conduct tests and on multiple bots and we are being told that if we order we won't get them until 2-3 weeks from now
Unread 22-02-2011, 23:00
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
IS IT MANDATORY TO USE THE LINE SENSORS?
Unread 23-02-2011, 07:55
RyanN's Avatar
RyanN
No? What gave you that idea?
Controls Mentor
@rnazaretian
Previous teams:
