Go to Post It was the stupidest rule, but a rule is a rule, and everyone has to follow them. - RyanN [more]
Unread 15-02-2011, 01:23
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Rookie DriveTrain Help~! plz
Hello all,
We are trying to do a four wheel drive robot, with four CIM/CIMpleBoxes one on each wheel.
We have a rectangular wheel base 27x37 with about even weight distribution.
The problem is when we turn, well, complete failure, the wheels skid and it locks up...
So an suggestions/help would be appreciated
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 15-02-2011, 01:32
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Re: Rookie DriveTrain Help~! plz
With your current configuration, assuming you are using 4 high traction wheels (either kitbot wheels or AndyMark wheels), the easiest solution would be to switch out one set of wheels for omniwheels of the same diameter. You can keep your gearboxes and code by doing that.
Good thing you're finding out now and not at competition! Good luck with the robot!
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 15-02-2011, 01:34
Chris is me's Avatar
AKA: Pinecone
Direct driving any wheel with the CIMpleboxes is a bad idea. The wheels will not have nearly enough of a gear reduction and will not have the torque needed to turn.
Unread 15-02-2011, 03:45
Mk.32's Avatar
AKA: Mark
We are going though the KOP shain + sprockets to btw.
So we need more torque to be able to turn or to go to omniwheels?
Unread 15-02-2011, 03:59
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
it would be a good idea to use the sprockets to add another gear reduction between the CIMple box and the wheels.
You might want to think about changing all 4 wheels to omniwheels at this point, since changing just 2 will give you a somewhat funky drive (turning point very close to the non-omni wheels).
The obvious disadvantage is that you can not resist being pushed sideways.
you should think about your game strategy and decide which change is best for you.
summarizing:
  • change the sprockets so you get more gear reduction between the cimple box and the wheel.
  • change 2 or 4 of your wheels to omni wheels.
Good luck and keep us posted if you need help.
-Leav
p.s.
At the regional, be sure to bring a camera and take pictures of drivetrains and mechanisms you find interesting, veteran teams a fountain of inspiration and knowledge for rookies!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 15-02-2011, 04:05
meebee's Avatar
meebee meebee is offline
FRC #2134
meebee is an unknown quantity at this point
Have you considered converting to a 6WD? If you're using the kitbot in long configuration this can be done quite easily.
Just add in a center pair of wheels and have them chained to either a cimple or corner wheel. 1/8" drop 6WD with little effort!
Unread 15-02-2011, 09:56
Congratulations, you have rediscovered the extreme difficulty of using skid steering with four traction wheels and a long wheelbase.
The problem is that you have too much side friction and not enough force to overcome it. One solution is to change your gearing to give you more force, though that will reduce your maximum speed.
The quick fix is to replace your front or rear wheels with omniwheels (mecanum wheels could also work, but they're a lot more expensive and might not fit in the same space). This will let you turn easily, though you'll need some driver practice to get used to the fact that the robot will turn around the end still having the traction wheels. Depending on the design of the rest of your robot, you will probably find one end or the other to be more appropriate for the omniwheels. Some teams have found that putting omniwheels on diagonally opposite corners works okay too, which would put the center of rotation at the center of the robot, but still has the risk of the other wheels skidding/jumping while turning.
It would also be possible to modify the surface of one pair of wheels to make them easier to slide, such as cutting horizontal grooves into the tread or wrapping a bunch of zip ties around it. Omniwheels are easier.
Unread 15-02-2011, 10:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
6wd would be the way to go, if you're using the kit chassis (or another chassis that could be modified for 6wd). But you didn't tell us what your chassis is--we all have to guess.
How about some pictures? we love pictures
Unread 15-02-2011, 10:49
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
solution (A. convert to 6wd tank, if you have the weight this drive-train is excellent and has taken many teams to world finals. however... if you don't have the weight this late in the season.
solution (B. Slick rear wheels, if you are using the KOP wheels than you need to buy a pair of these, or contact a team from a few years ago that might have some laying around
i think that this is the plastic tread wheel, if someone could verify for me
http://www.andymark.com/ProductDetai...ctCode=am-0494
if not than any team around last year or 2008 has a set of 8 inch sick wheels.
although omni is a good option as well, i have found that putting a pair of slick wheels on is cheaper, more effective, and lighter.
Unread 15-02-2011, 10:51
MrForbes's Avatar
AKA: Jim
Those are three dirty words for many teams
Unread 15-02-2011, 10:55
AKA: Pinecone
Slick wheels are not particularly good at providing force for a robot. Honestly, I don't see why teams that use them bother even driving them with chain.
Omni wheels are better, because they do have traction in one direction. They have no traction in the direction you want them to have no traction in!
Unread 15-02-2011, 13:07
Mk.32's Avatar
AKA: Mark
Thanks for the info everyone,
we are using the kit frame, however going 6 wheel drive might be an issue with the way built our forklift.
I will get pictures up later for you all the see
Unread 15-02-2011, 14:02
MrForbes's Avatar
AKA: Jim
the center wheel does not need to be centered front to back, it could be off center by 6" or so and still do the job of making the robot easy to turn.
Unread 16-02-2011, 00:32
Mk.32's Avatar
AKA: Mark
Okay after talking it over with the team,
we are going to be trying out some omniwheels then if that doesn't work going 6 wheel drive. 6 wheel drive is a problem since our tower supports are in the way.
Unread 16-02-2011, 00:42
Thomas_S Thomas_S is offline
"Speedy Squirrel"
AKA: Thomas Sessum
FRC #1927 (Team Tempest)
Team Role: Driver
Thomas_S is an unknown quantity at this point
Mk.32 we used a robot last year with front traction wheels and rear omni wheels and really didnt run into any problems. its true pivot point was in between the front wheels and it gave us exceptional control and finesse when driving in the competition. its a good, simple fix to that problem. we competed fairly well and for the game it worked well, but im personally biased to a 6 wheel tank for its simplicity.
