Re: Robot driving off.
More than likely it's a problem in mecanumDrive_polar itself. I have heard some nasty things from other teams about it.
What I had to eventually do was program my own drive train (which works awful, but that's what the remainder of the season is for!) until we got a mecanum drive that suits our liking. But before you go off and make your own, try getting rid of the Timer.delay(0.005); line. I don't know why you'd want to delay your operatorControl, as it would just make your robot move in little spurts. |
drive.mecanumDrive_Polar(stick.getDirectionDegrees(), stick.getMagnitude(),stick.getRawAxis(4)); |
Bluedog24,
You can print out the values of your joystick - perhaps they aren't zero as you expect. Robby, It's a good idea not run your control loop flat out - you only get new joystick values every 50ms, so delaying 5ms isn't going to hurt anything. This will allow camera code, dashboard code, etc to get a chance to run. In fact, there's a new method DriverStation.waitForData(long ms) that would be handy to use. |
Thanks for clearing that up.Quote:
Axis 4 is the right stick's Y axis. |
here is my motor driving code, complete with mecanum
package com.robototes.abomasnow;
import edu.wpi.first.wpilibj.*;
public class Driver {
private Jaguar FLjaguar;
private Jaguar FRjaguar;
private Jaguar RLjaguar;
private Jaguar RRjaguar;
private boolean mecanum;
private boolean wheel4;
* Usage: Driver robot = new Driver(1,2);
public Driver(int L, int R) {
FLjaguar = new Jaguar(L);
FRjaguar = new Jaguar(R);
wheel4 = false;
mecanum = false;
* Usage: Driver robot = new Driver(1,2,3,4);
public Driver(int FL, int FR, int RL, int RR) {
wheel4 = true;
FLjaguar = new Jaguar(FL);
FRjaguar = new Jaguar(FR);
RLjaguar = new Jaguar(RL);
RRjaguar = new Jaguar(RR);
mecanum = false;
* Usage: Driver robot = new Driver(1,2,3,4,true);
public Driver(int FL, int FR, int RL, int RR, boolean mecanum) {
wheel4 = true;
this.mecanum = true;
* This function takes in one input, speed. If you dont have the mecanum
* flag defined, it will skip to just setting the speed. Otherwise, it will
* set the speeds of the first two Jaguars. If you are using four wheels
* in the constructor, it will also set those speeds accordingly.
public void drive(double speed) {
if (!mecanum) {
FLjaguar.set(speed);
FRjaguar.set(-speed);
if (wheel4) {
RLjaguar.set(speed);
RRjaguar.set(-speed);
} else {
this.holonomicDrive(speed, 0, 0);
* This takes two inputs, left speed and right speed
* it sets the first two jaguars
* then it checks if you called Driver with 4 motor ports
* if that is true, it sets the values for the back two motors
public void tankDrive(double left, double right) {
if (!mecanum) {
FLjaguar.set(left);
FRjaguar.set(-right);
if (wheel4) {
RLjaguar.set(left);
RRjaguar.set(-right);
* TankDrive, xbox 360 input version
public void tankDrive(Xbox foo) {
this.tankDrive(-foo.getLeftStickAxes()[1], -foo.getRightStickAxes()[1]);
* Makes sure we dont send a n<1 value to the jaguars, they dont like that
double limit(double num) {
if (num > 1.0) {
return 1.0;
if (num < -1.0) {
return -1.0;
return num;
double maxOf4(double one, double two, double three, double four) {
return Math.max(Math.max(Math.abs(one), Math.abs(two)), Math.max(Math.abs(three), Math.abs(four)));
* This brilliant hack was make by our team's all around awesome mentor, Dimitri
* Dont touch it
* Takes one input, input. if the input is positive, it squares it. If its
* negative, it squares it while preserving the sign. It returns the input.
* It allows greater control of speed while preserving the ability to go at full
* speed
public double fiddleWithSpeed(double input) {
if (input > 0) {
input = input * input;
} else {
input = -input * input;
return input;
public void holonomicDrive(double power, double slide, double spin) {
* This is a correct mecanum wheel drive function
double fl, fr, rl, rr;
fl = power + slide + spin;
fr = power - slide - spin;
rl = power - slide + spin;
rr = power + slide - spin;
double max = this.maxOf4(fl, fr, rl, rr);
if (max>1) {
fl = fl/max;
fr = fr/max;
rl = rl/max;
rr = rr/max;
fl = limit(/*fiddleWithSpeed*/(fl)); //don't need fiddleWithSpeed for victors, you will for jaguars
fr = limit(/*fiddleWithSpeed*/(fr));
rl = limit(/*fiddleWithSpeed*/(rl));
rr = limit(/*fiddleWithSpeed*/(rr));
if(power != 0 || slide !=0 || spin != 0) {
System.out.println("#############################################");
System.out.println("power: " + power + " spin: " + spin + " slide: " + slide); //debugOut
System.out.println("FLSpeed: " + fl + " FRSpeed: " + fr);
System.out.println("RLSpeed: " + rl + " RRSpeed: " + rr);
this.set(fl, fr, rl, rr);
public void arcadeDrive(double power, double turn) {
double left,right;
left = power - turn;
right = power + turn;
double max = Math.max(left, right);
if (max > 1) {
left = left/max;
right = right/max;
left = limit(fiddleWithSpeed(left));
right = limit(fiddleWithSpeed(right));
this.set(left, right);
public void arcadeDrive(JessPad Fool) {
this.arcadeDrive(-Fool.getLeftStickAxes()[1], Fool.getLeftStickAxes()[0]);
public void stop() {
this.drive(0);
public void set(double left, double right) {
this.tankDrive(left, right);
public void set(double FL, double FR, double RL, double RR) {
this.FLjaguar.set((limit(FL)));
this.FRjaguar.set((limit(-FR)));
this.RLjaguar.set(((limit(RL))));
this.RRjaguar.set((limit(-RR)));
public double getAVGSpeed() {
* If there are 4 wheels defined, return the values of all the jaguar values averaged, otherwise,
* return the speeds of the two wheels averaged.
* I know its ternary abuse, but it works (i tested it in javascript)
return wheel4 //condition to test
? (this.FLjaguar.get() + this.FRjaguar.get() + //if its true
this.RLjaguar.get() + this.RRjaguar.get())/ 4 //cont.
: (this.FLjaguar.get() + this.FRjaguar.get()) / 2; //if its false
public void goForward() {
this.holonomicDrive(0.5, 0, 0);
public void goBackward() {
this.holonomicDrive(-0.5, 0, 0);
public void turnRight() {
this.holonomicDrive(0, 0, 0.5);
public void turnLeft() {
this.holonomicDrive(0, 0, -0.5);
#7
I got it fixed, switched around getDirectionDegrees and getMagnitude.
Thanks for the help. ![]() |
#8
isNewControlData() vs. waitForData()
The both get the job done, but there are differences:
#9
And in the digital world everything runs in little spurts, only real life is continuous. The trick is to keep the spurts below the threshold where you notice them, like TV or movie images. |
