Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 13-02-2011, 18:59
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Wave Robotics 2826 Mini-bot 1.45 sec!
Check out Wave Robotics' latest mini-bot design! Shot in real-time HERE and at 420 FPS HERE or just check out our channel HERE.
Note: Battery is on the mini-bot; only thing that is tethered is the switch to turn the mini-bot on and off.
Deployment mechanism to be coming soon!
P.S. Sorry about the low res ]
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 13-02-2011, 19:28
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Re: Wave Robotics 2826 Mini-bot 1.45 sec!
nice jw is you team using magnets or two small wheels and just a battery
Unread 13-02-2011, 22:16
FUN Show Host
Good question! We are using custom "wheels" with no magnets. Really it just comes down to the physics behind the challenge. What really helped us was understanding the motor power curves, increasing the traction interface to the pole, and having the right amount of applied power to weight ratio for the mini-bot.
CD Moderator
Unread 14-02-2011, 13:20
Halliday Halliday is offline
FTC #0128
Halliday is an unknown quantity at this point
Just wondering, how do you plan to start the minibot for deployment?
Unread 14-02-2011, 14:33
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Sweet !!
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 14-02-2011, 14:40
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
How did you provide traction on your custom "wheels"?
-Mr. Van
Coach, Robodox
Unread 14-02-2011, 15:41
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Mr. Van, I can provide a few hints on the traction material, but don't want to give away the farm quite yet. Plus, what fun would it be if I just told you. ; )
1. The material is 100% legal,
2. The material is not in the Tetrix parts makeup
3. The material has a higher coefficient of friction to steel than rubber (thus is not rubber)
4. The material can be easily found online with the right magic words
The real trick in increasing the traction was making sure we were applying the force to the pole normal to the axis of rotation of the wheel. Our first ten or so protos were a failure (or at least a relative failure) because we were dramatically overthinking the retaining mechanism.
I promise that we will divulge everything at the Wisconsin Regional in week 2. Of Course, by then, everyone will probably have a 1 second minibot and we will be behind the ball.
Unread 14-02-2011, 18:59
Gatlin18 Gatlin18 is offline
FRC #2373 (Crickets)
Gatlin18 is an unknown quantity at this point
Did you make your wheels out of Polycarbonate? I'm looking at the list of materials usable on the minibot, and that is the only thing I've seen used as wheels. Not sure about the traction on them, because I don't think anyones ever compared it straight to rubber.
EDIT: Just thought, you could put a nonslip pad (that comes in a roll so it would be easy to put on where the rubber would be of a regular wheel, these still being made of polycarbonate), that would have better traction than rubber.
Unread 15-02-2011, 01:02
Mentor - 2826
AKA: Jake Fischer
No Non-slip pad or Polycarb. No aluminum in the wheels either
Unread 15-02-2011, 02:06
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Inverted surgical tubing? I really have no idea!
This video is going to be the source of inspiration for our minibot team, which is just starting to push 3 seconds.
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 15-02-2011, 02:22
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Very impressive, will be interesting to see how it holds up against the competition
Unread 15-02-2011, 02:45
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Are you using rolls of electrical tape as wheels? Also, did you remove the standard tetrix gearbox, and if so, what did you replace it with?
Jason
Unread 15-02-2011, 07:27
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
Polyurethane wheels
FRC - STARS of Cypress, 2008, 2009, 2010
FTC - SOAR Club - 2011
FLL - DNAbots - 2009, 2010
BEST - STARS of Cypress - 2008, 2009, 2010
MATE - STARS of Cypress - 2008
MATE - SOAR Club - 2011
VEX - Discobots - 2010
Robofest - 2008
Houston: Energy City of the Future - RNKL Engineering - 2009
Unread 15-02-2011, 11:34
Mentor - 2826
AKA: Jake Fischer
As far as I know, Polyurethane is not on the approved list, so from our view, no, they are not polyurethane
We did try electrical tape and many varieties of heatshrink tubing, but none gripped well enough for our purposes.
The only thing I will comment on the gearbox is that it is so incredibly inefficient that you are losing more than 60% of your potential tractive energy inside this box. This is one of the main reasons that we are seeing so many smoked gearboxes. We have destroyed 3 of them ourselves. They need to be dramatically improved
Unread 15-02-2011, 11:40
Mentor - 2826
AKA: Jake Fischer
One major clarification on the timing illustrated in this post: The 1.45 seconds was our fastest recorded time, with our slowest recorded time at 1.67 seconds. The video that was posted was a 1.6 second run. We have good reason to believe that the next proto iteration we are testing tonight should approach the 1.25 second mark.
Anyone that breaks the 1 second mark, please post that it is possible. I know in theory, the math and physics support it, but ... well I don't need to finish the comment.
Right now we are treating the one second mark akin to the sound barrier and X1. We know it should be possible, but we will believe it when we see it.
As for deployment, we have a pretty robust system in place and is easily under 1 second. We will most likely have to tune the "launch" down a bit to prevent destroying our minibot.
