Go to Post If this strategy backfires on any alliance that attempts it, they will have no one to blame but themselves. Be smart - know the risks before proceeding. - Travis Hoffman [more]
Unread 02-15-2011, 09:27 AM
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: Pneumatics and C++
The Compressor class will manage everything to do with the running the compressor and turning it on/off based on the pressure switch. You just have to pass it the slot/channel of the spike relay and the pressure switch and call Start(). You will use the Selenoid class to control your solenoid. It has a Set() function to turn it on/off. Below is a simple example but it will need a little more work before it is functional. First you need to set the proper channel/slot values. I just put zeros in so you must put the correct values here for it to work. Also, I just guessed that to open your grabber you would turn your selenoid off and to close it you would turn your selenoid on. Good Luck!!
Grabber.h
#include "Compressor.h"
#include "Solenoid.h"
class Grabber
public:
	Grabber();
	~Grabber();
	void Open();
	void Close();
private:
	Compressor* pCompressor;
	Solenoid* pSolenoid;
Grabber.cpp
#include "Grabber.h"
Grabber::Grabber()
	this->pCompressor = new Compressor(0,0,0,0);
	this->pSolenoid = new Solenoid(0,0);
	this->pCompressor->Start();
	this->pSolenoid->Set(false);
Grabber::~Grabber()
void Grabber::Open()
void Grabber::Close()
	this->pSolenoid->Set(true);
