Go to Post I just want to say that the rack 'n roll was my first year with FIRST! It was the best thing I ever did. I cant wait to learn more when we get to start up again! - ctorloey [more]
Go Back   Chief Delphi > Competition > FRC Game Design
Unread 29-01-2011, 17:14
brian3795 brian3795 is offline
FRC #3795
brian3795 can only hope to improve
Starting position
Trying to decipher the game rules for starting position. This is our take:
The bot starts facing your scoring pegs, with the rear bumper outside the line between your opponent's poles. IOW, your photo sensor is set up over a tracking line at the start of a match.
The ubertube is already in place on the bot before the match begins.
Initial bot placement is randomly determined by some method, so you won't know whether or not you'll have to deal with the split tracking line until the time of the match.
Are we close?
Unread 29-01-2011, 18:23
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Starting position
Read it again:
<G04> Each ROBOT must be positioned on the FIELD so that the BUMPER closest to it‟s ALLIANCE‟S PLAYER STATION breaks the plane formed by the POSTS of the opposing ALLIANCE‟S TOWERS.
(emphasis mine)
However, from the picture and description in section 2.2.2, the gray tape tracking lines extend farther out than the towers. So it appears you can start with your sensors above the line.
(since 2004)
Unread 02-02-2011, 16:53
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
does the hostbot start with an Übertube?
Unread 02-02-2011, 18:03
Yes. All robots start with one in contact with the robot.
Unread 11-02-2011, 21:09
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Okay, It says that the front bumper has to break the plane of the tower, does that mean the back bumper can't break the plane?
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 11-02-2011, 21:14
GaryVoshol's Avatar
Cogito ergo arbitro
Since the plane defined by the TOWERS is only 1.74" wide, it would be pretty hard to have both front and back BUMPERS breaking that plane. So no, only the front BUMPER can break the plane, not the back. This puts all ROBOTS an equal distance from the GRIDS.
(since 2004)
Unread 14-02-2011, 23:20
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Well, the towers are defined as "an assembly composed of base, post, and tower." And I believe the base is 30" in diameter. So if you have a wide bot, you could conceivably place both bumpers in the plane.
www.sharkattack744.com
Unread 15-02-2011, 07:40
GaryVoshol's Avatar
Cogito ergo arbitro
Did you read the rule? (I quoted it for you above.) You have to be lined up in the plane of the POSTS, not the BASE. That's only 1.74" of wiggle room.
(since 2004)
Unread 15-02-2011, 10:03
It would be very easy to do that if you turned the ROBOT sideways. But as long as we're actually reading the rule we should note that it doesn't speak of "front" or "back" BUMPERS. You emphasized the relevant word: closest.
Unread 15-02-2011, 10:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
To address the OP. Your alliance will determine what bot starts where. The FMS only chooses your player stations.
Unread 15-02-2011, 10:28
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
I am wondering if you need to start on the lines, or if the horizontal positioning of the robots is up to the teams.
Unread 15-02-2011, 11:14
GaryVoshol's Avatar
Cogito ergo arbitro
That also is up to the alliance.
(since 2004)
