Go to Post Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. - Andrew Schreiber [more]
Unread 15-02-2011, 11:05
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: 1/2" Shaft Encoders
Originally Posted by DavidGitz View Post
Is this a "rule of thumb" or have you actually seen that without using some sort of precision rotation method to change the diameter that even a small angle offset will result in the behavior I described?
I suppose if you had a very nice vise with a vertical V-groove and a more-than-decent mill you might be able to pull it off if you can get it centered down the shaft (probably with some fancy edge-finding). The lathe makes it easier to just center-drill, drill and ream all from the tailstock. Or you can choose to turn your own pin onto the end like I mentioned above. Any misalignment at all with the pin could result in dead zones or even scratch the disk on the lenses. Of course if open-loop works for you, go with it
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
