Go to Post Dave has said that straight out. Well, straight by dave standards. - phrontist [more]
Unread 15-02-2011, 10:30
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Mecanum Troubleshooting
What are some possible points of failure when a mecanum drivetrain doesn't drive straight sideways (i.e. curves when strafing)?
Being a programmer, I'm prone to ruling out code as a problem, but feel free to question it.
Here are some possible issues:
1. Frame is not rigid enough, and wheels not keeping contact
2. Wheels not spinning the same speed (implement PID?)
3. LOTS of slipping (too much acceleration?)
Anything else you can think of? Or do any of these stand out as a common issue?
Unread 15-02-2011, 10:43
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Mecanum Troubleshooting
having done mechanum last year i can tell you how to solve 50 percent of this problem, go to ace and get some Graphite Lubricant. use this on all of the mechanum rollers being very careful to not get it on the roller surface. this makes the rollers much more consistent in their rolling and makes it work a lot better. the second thing to to is check all of your bearings and make sure they are not binding. after that there is not much you can do. i dont think the programing is usualy at fault for not driving straight, but it is one place where programing can solve the mechanical error. PID might be a good thing, ramping code is also useful.
Unread 15-02-2011, 10:47
Curving while strafing sounds like you might have more weight on one end of the robot than the other. The wheels on the heavier end will usually tend to run a little slower than the wheels on the lighter end.
FRC #0107
This might help: it drives straight when going forward, just not when strafing. Maybe that points to the rollers?
Unread 15-02-2011, 11:55
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
When using four separate gearboxes (I'm assuming you are for proper mecanum control), small differences in mechanical and electrical resistance have a much greater effect. I would use PID controllers with encoders on each gearbox to control their rate.
Unread 15-02-2011, 12:10
Nah, I'm with Alan on this. An unbalanced mecanum will tend to curve in strafing. If your CG is not in the middle front-back, it'll curve.
Unread 15-02-2011, 13:08
FRC #0107
Oooooh boy... that'll be fun to balance out... Would individual PID values account for misbalanced weight?
Unread 15-02-2011, 13:18
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
All the listed posts will address separate problems which will get you closer to optimum performance; however, one way to ensure you correct for ANY problem (even the ones you don't know about) is to hook up a gyro, and have that autocorrect your orientation. We don't have any experienced programmers, but got the gyro working. Do some searches for how to get that wired/coded.
Unread 15-02-2011, 13:20
Might depend on the weight. If your battery, compressor, cRIO, and power distribution are all on one end of the robot, I'd say you'd need to move one or more of them to the other end, if possible. If you're already fairly balanced, but having an arm out causes you to curve, a gyro combined with PID might work.
Unread 15-02-2011, 13:29
Yes, that would be consistent with a problem with the rollers. The rollers don't spin when you are driving straight forward. They spin a LOT when you are strafing.
To rule out the weight distribution as the cause of the problem, try adding some temporary weight to the lighter end of the vehicle and see if there is any improvement.
Unread 15-02-2011, 13:32
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
There are many things that can affect this. Although, the things you can do to help the situation are..
1. Balance same weight on all wheels
2. Tighten rollers to same tension
3. Solve any other issues that may give any wheel more power or traction than the other wheels.
4. Try to program in correction for the what can't be fixed mechanically
Unread 15-02-2011, 13:39
http://www.chiefdelphi.com/forums/sh...99&postcount=4
