Go to Post If you are new to these forums, you might want to observe the discussions a while before diving in with opinions, emotions, and expertise. - Andy Baker [more]
  #46   Spotlight this post!
Unread 08-02-2011, 11:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: LabVIEW Encoder not reliably returning Rate
Better question: What part of the FPGA encoder handling changed? I never had any issues with it, it worked as expected, why not leave it?
Kettering Motorsports
  #47   Spotlight this post!
Unread 08-02-2011, 20:20
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Originally Posted by apalrd View Post
It worked two years ago.
After a mid-season correction.
  #48   Spotlight this post!
Unread 08-02-2011, 20:42
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
we at team 171 had the same problem and we don't really know how to write rate code (We are new to using labview). but we found out that you can alternate encoders quickly and use them in a series and not in parellel and this fixed our encoder issues.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
  #49   Spotlight this post!
Unread 15-02-2011, 12:09
Shawnk Shawnk is offline
FRC #1802
Shawnk is an unknown quantity at this point
ANDYB - "we at team 171 had the same problem and we don't really know how to write rate code (We are new to using labview). but we found out that you can alternate encoders quickly and use them in a series and not in parellel and this fixed our encoder issues."
Would you be able to post an example of this? Team 1802 is looking for some help and we dont know how to write our own rate code either.
  #50   Spotlight this post!
Unread 15-02-2011, 16:58
Coda Coda is offline
FRC #0171
Coda is an unknown quantity at this point
What we meant to say was that if the Encoder Get Function was placed inside of sequential frames of a flat sequence structure. One after another. You can tunnel the rate outside of the sequence structure. That is our solution, its rather simple and doesn't cure the problem, but it treats the symptoms and you don't have to write rate code
  #51   Spotlight this post!
Unread 16-02-2011, 11:29
robotsteve robotsteve is offline
FRC #2839 (Daedalus)
robotsteve is an unknown quantity at this point
Computing Rate
What do you mean by "writing your own rate code"? We're using Java, not Labview.
Thanks-
Steve
  #52   Spotlight this post!
Unread 16-02-2011, 11:31
Can you explain what this means ??
Thanks-
Steve
  #53   Spotlight this post!
Unread 16-02-2011, 12:59
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
I think it would be extremely beneficial to all of us if you could perhaps post a screenshot so we can all try it ourselves
  #54   Spotlight this post!
Unread 16-02-2011, 14:13
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I've sat down and tried using all of the quadrature decoding resources and discovered something a bit odd. In 4x decoding, the 2 odd numbered decoders return rate correctly, the other 2 do not. In 1x or 2x decoding, the first 3 even numbered decoders and the last (odd) decoder return rate correctly.
I've modified the Open and Close VIs for the Counter and Encoder APIs to have them only use the ones that work. If you need the rate output, you can replace these after installing the update. Extract this to C:\Program Files\National Instruments\LabVIEW 8.6 or wherever you installed LabVIEW. If you install a new update or reinstall anything, you need to replace them again. Note that this may cause confusion for your team if you use more than one computer for development and you forget to install these on all development machines.
The downside to this work-around is that you now can only use 2 encoders in 4x mode and 4 encoders in 2x or 1x mode.
You always have the option to write your own rate algorithm based on the distance instead, but that may be less accurate.
-Joe
  #55   Spotlight this post!
Unread 16-02-2011, 17:44
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
OMG! We have spend two 5am-7pm days working around the builders trying to fix the same encoder problem. Now we find out it wasn't our code or hardware AND their won't be a fix?
I have no clue how to write our own code. Can anyone explain?
  #56   Spotlight this post!
Unread 16-02-2011, 18:34
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
This was our fix for exactly the same problem. We created our own encoder class and put in this PIDGet method:
double RhsEncoder:IDGet()
double dfNewRate;
double dfNewCount = pQuadrature->GetDistance();
double dfNewTime = GetClock();
if (pQuadrature->GetStopped())
dfNewRate = 0.0;
else
// calc the rate
if((dfNewTime - dfLastTime) == 0.0)
dfNewRate = 0.0;
else
dfNewRate = (dfNewCount - dfLastCount)/(dfNewTime -
dfLastTime);
dfLastTime = dfNewTime;
dfLastCount = dfNewCount;
return(dfNewRate);
HTH
  #57   Spotlight this post!
Unread 16-02-2011, 21:26
Originally Posted by lynca View Post
We had a similar issue in Java.
We had one returning a reasonably rate and a second encoder that was returning essentially garbage. We spent an hour debugging, swapping connectors and twiddling without any success.
We eventually just wrote our own rate functions and moved on.
What do you mean about writing your own rate encoder??
Please explain --
Thanks-
Steve
  #58   Spotlight this post!
Unread 16-02-2011, 23:46
Originally Posted by wireties View Post
		   dfNewRate = 0.0;
When would (dfNewTime - dfLastTime) ever be zero; and if it were, wouldn't you want
double dfNewRate;
dfNewRate = 0.0;
else
// calc the rate
dfNewRate = dfLastRate;
//don't reset dfLastCount; let it accumulate
else
dfNewRate = (dfNewCount - dfLastCount)/(dfNewTime - dfLastTime);
dfLastRate = dfNewRate;
return(dfNewRate);
  #59   Spotlight this post!
Unread 17-02-2011, 18:34
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Writing fixed timebase rate codes (as opposed to interrupt-triggered ones)gets complicated, especially at low rates when there are relatively few ticks per loop (aka discretization error). Looks like we'll have to add a second DSC and DIO module to our already-completed electronics board be able to use closed-loop control for our drive motors since all of our DIO channels are used (assuming I'm understanding the "every other channel" workaround correctly).
Unless: Joe - any chance someone at NI could provide some reference code based on an interrupt-driven approach instead of a timed loop approach? We just don't have enough time between now and ship date to write and test our own version.
  #60   Spotlight this post!
Unread 17-02-2011, 20:35
I don't think you are reading my post very carefully. The issue has nothing to do with the I/O on the side car... only the decoding engines in the FPGA. Adding a side car will not help. You simply need to allocate the encoder or counter objects that have functioning timer modules (rate calculators). I have provided VIs that will do just that. If you use the VIs I posted, you don't need to call anything twice or whatever other things people have been saying to do. Just use the API as it was intended and it should work for you.
I don't have that ready to go, so I would be trying to make sure it was perfect too, and with just a few days left, it's probably not worth while and wouldn't be perfect. Perhaps some other team has implemented it this way and wants to share.
The work around above allows you to read up to 6 encoders with the FPGA calculating rate for you. Only if you need more than 6, do I recommend writing your own rate algorithm.
-Joe
