Go to Post If they ask you to stop - you stop. - techhelpbb [more]
Unread 15-02-2011, 13:41
Re: Banebots RS-775 Case Short
David,
I just think this method is bad on so many levels. Did they give you any idea on what form of debris may be present that they are trying to zap? If this is metal flakes left over from balancing operations, shorts to case are going to be the least of the problems. Depending on the size of the debris, this may be a permanent fix or a permanent short.I won't have access to a motor for a while, can you examine one of yours?
