Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 15-02-2011, 13:58
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Question from a ROOKIE Team
Originally Posted by Matt Krass View Post
If it's a slow blink, you're almost certainly looking at debris, the question is whether or not it is causing a transient problem or if your FETs have already fried.
I have never seen the "slow blink" due to a debris problem. If there has been a debris issue it almost always causes instant failure of a Jaguar. From the document that I referenced earlier:
"Fault Conditions
A slow flashing Red LED indicates that the MDL-BDC detected one of the following fault conditions:
�� Power supply under-voltage
�� Over temperature
�� Over current
�� Limit switch activated in the current direction of motion
When a fault condition occurs, the motor shuts down and the LED indicates a fault state during the
fault condition and for 3 seconds after the fault cause is cleared (except for the limit switch fault,
which is cleared instantly). A slow flashing Yellow LED indicates that the MDL-BDC is not receiving a
valid control signal."
This statement is an oxymoron.
Hotwiring motors is not a safe proposition, no matter how steady your hands are. There is a reason FIRST has us use circuit breakers and reliable connections, and it's not to cost people money or time, it's a SAFETY FEATURE.
I'm sure there are many different ways someone could "hotwire" a motor. What I was referring to above (and why I put in the words "please exercise safety") is to use common sense*. I can think of several ways to "hotwire" a motor without having to have a "steady hands" requirement, such as:
-If the motor is not installed on a robot, put it on a table and clamp it down.
-Use a circuit breaker inline with the power connection. All Circuit Breakers that attach to the PD Board are compatible with a standard female 12 AWG connector.
Can anyone else think of some ways to safely "hotwire" a motor?
