Go to Post I love how the people of Chief Delphi can turn a spam post into a somewhat non-timewasting thread. Either way, congrats CD and thanks for this ;) - logank013 [more]
Unread 14-02-2011, 18:31
Re: 4" Wooden Mecanum Wheel
Originally Posted by TheOtherGuy View Post
The third link you provided gave a ghastly equation (well, a few relatively nice equations with lots of substitution ) on the last page for estimating the parabola, yet when I plot it, the length is off by quite a bit (should go to sqrt(7/2))...
I don't follow you. What are you plotting and what are you comparing it to?
Unread 14-02-2011, 18:48
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by squirrel View Post
heh...I used the compound rest. I suggested that the error would be pretty low if we made the half roller as two cones. Kevin figured the angles at 6 and 16 degrees, I set the compound rest to those angles to turn it. then we sanded the lump in the middle to radius it.
Squirrel,
This is how we turn the rollers for our mecanum wheels: http://www.youtube.com/watch?v=1-Zvib5nZVw&hd=1
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 14-02-2011, 22:03
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Sorry, should have elaborated. The blue line is the ellipse I'm currently using for the roller contour, and the purple is the equation found on the last page of the third link. Specifically, the length of the roller L is 2sqrt(7/2)" (from ellipse equation), R is 4", and r is .5". The equations are then:
D = R – r = 4-.5 = 3.5
F = (sqrt(2*3.5^2+(1/2*sqrt(7/2))^2))
G = (sqrt(4*3.5^2+(1/2*sqrt(7/2))^2))
T = (4sqrt(2)/ sqrt(2*3.5^2+(1/2*sqrt(7/2))^2))
A = 32*(2*r-G*(T-1)) / (L^2*(T+1)^2)
But when I plot it, the roots aren't +/- sqrt(7/2). Oh well, maybe I'm just no good at copy-pasting.
Unread 14-02-2011, 22:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Thank you for posting a link to the video! I thought about using a coarse abrasive if we used rubber rollers, but that would work well with wood too. It makes a mess, but it's an easy way to make the parts.
Unread 14-02-2011, 23:05
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Hey Matt! How's MIT?
Mr. Forbes mentioned those as a first solution, too. It may be worth looking into. I just had a crazy idea that may or may not work, but if it's possible to drill and tap into the end of a #10 threaded rod, maybe I can screw on a small washer onto the ends of the rod.
MIT is challenging, but also fun.
Working from http://www.engineersedge.com/screw_threads_chart.htm, tapping the threaded rods seems as though it will present its own set of difficulties.
Your 10-24 threaded rod has a 0.138" minor diameter (total diameter minus the depth of the threads). This means you will need to use 4-48 or small fasteners to have any material between the inner screw and the outer threaded rod.
Tapping #4 machine screw holes in steel by hand is a pain and repeating the process 48 (or is it 96?) times would likely result in several broken taps/drill bits.
Also, I believe you get into issues with loading on the screws and threaded rod. Speaking qualitatively #4 screws are at risk of breaking during shock loading.
Unread 14-02-2011, 23:06
MrForbes's Avatar
AKA: Jim
Kevin and I talked on the phone about it, we came up with a few other solutions...like using round, internally threaded, 1/4" od spacers. And a few other ideas.
Good to hear you're keeping challenged, that was always your problem
Unread 14-02-2011, 23:15
Your parabola plot is correct.
The equation simplifies to y= 0.5-0.066683598*x^2
The roots are not supposed to be +/-sqrt(7/2). Why do you think they should be?
If you want the radius to go to zero, you need a longer roller.
Unread 15-02-2011, 07:59
Your parabola plot is correct...
I found the problem: the ellipse you plotted was not correct.
The ellipse you plotted was y=sqrt(4-x^2/2)-1.5 (see attachment 1).
The ellipse should be (sqrt(64-2x^2)-7)/2 (see equations #1 and #4 of attachment 2).
The ellipse in attachment 2 is plotted in attachment 3. It is a close (but not exact) fit for the parabola you plotted.
If your rollers are indeed contoured per the ellipse in attachment 1, then they are quite a bit off.
[edit]The good news is, this means a larger radius for your end fastener[/edit]
Name:	1 wolfram.png
ID:	10121  Click image for larger version
Name:	3 ellipse.png
Unread 15-02-2011, 10:48
Unregistered User
AKA: Kevin Forbes
From eq.#1, it looks like you used the diameter of the mecanum wheel as the radius instead of the radius. The equation for the ellipse without translation should be y^2/4 + x^2/8 = 1. The second ellipse needs to be translated up 3 units in order to give the roller a diameter of 1 in the middle, so the second equation is (y-3)^2/4 + x^2/8 = 1. Solving for y, you should get 3/2, and plugging that back into the first equation gives roots of x as +/- sqrt(7/2).
Intersection of two ellipses
Ellipse shifted down 1.5
Roots of ellipse shifted down
I did a quick check on the wheel I CADed, and the rollers do indeed follow these ellipses (and have the correct side profile on the wheel itself).
Heh, just checked back on the parabola equation, seems I made a small error in setting the radius of the wheel R equal to 4" instead of 2"! That would do it. Here is the fixed parabolic equation with the ellipse above. Sorry about the confusion.
Unread 15-02-2011, 12:27
I used the radius that you gave me:
Heh, just checked back on the parabola equation, seems I made a small error in setting the radius of the wheel R equal to 4" instead of 2"! That would do it. Sorry about the confusion.
Not to worry. The difference between the ellipse and parabola is probably negligible for these size rollers anyway.
I did the analysis mostly to satisfy my own curiousity. However, for larger rollers requiring expensive tooling to be commercially produced, it might be worth using the parabola instead of the ellipse.
Unread 15-02-2011, 14:05
MrForbes's Avatar
AKA: Jim
it gives me a warm fuzzy feeling to see my son arguing about (I mean discussing) equations
Unread 15-02-2011, 14:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
only in FRC....
wood=fragile, carve them from solid plexi
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 15-02-2011, 14:59
MrForbes's Avatar
AKA: Jim
We try not to solve problems by throwing technology at them...we like to think of ways to make stuff using supplies/equipment that we have already, or can find easily. Big chunks of plastic and the machines needed to machine them to complex shapes, are not stuff we have or can get locally.
Unread 15-02-2011, 16:54
joek's Avatar
good point, then i suggest metal
