Go to Post Volunteers are in short supply and we always need more. - Koko Ed [more]
Unread 15-02-2011, 14:09
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Program 2 coil solenoid
Alan - That is a good point. I tend to avoid using shift registers if at all possible, as I think it can be detrimental in troubleshooting effectively, but that's just me. And I would still be vary wary about implementing them in the FRC Teleop.vi as a poor implementation could lead to other (and possibly unforeseen) problems in the future. A better idea to me would be to use a For Loop, at least then you can definitively control how many times a loop will run before exiting, compared to a While Loop where you are more likely to be checking on an external (from the Teleop.vi) input.
But the application that you stated, using shift registers in place of multiple feedback nodes is great!
