Re: Importing error
the service pack also will not install.
Re: Importing error
Joe,
Good to hear from you again this year. Let's see if we can resolve the import issue. Depending on the type of ProE file it may not import correctly. For example, some types of assembly files may have issues and need file renaming and other techniques. However, I have checked all files related to FTC and the field and there were no problems on my machine. Please email me a single file that is causing a problem and I will check it for you. With regards to RAM, keep in mind that on a 32 bit system you have to use the 3 GB switch. See the Help file for details. My machine has 8 Gigs running on Windows 7 64 bit and it sees all the RAM. |
Re: Importing error
i have attatched 1 or 2 of the files here, in a zip.
Re: Importing error
JoeK,
Thanks. |
Re: Importing error
JoeK,
Here they are as Inventor IPT files. No problems with opening. In Inventor, click Open > set Files of type to Pro/ENGINEER (*.prt*, *asm*) > select the file. plate_6x2.ipt wheel_101mm_4-in.ipt |
Re: Importing error
thanks, i tried that, but they wouldn't work, possibly because the school's comps don't have many of the addon programs for inventor
