Go to Post Are you confused yet? - Andy Grady [more]
Unread 15-02-2011, 14:48
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Exclamation How do I wire a Toggle Rocker Switch
as title
1793 FTW
Unread 15-02-2011, 14:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do I wire a Toggle Rocker Switch
That depends on what you want to do with it, and what kind of switch it is (how many terminals does it have?).
More info would help us answer your question.
Unread 15-02-2011, 15:00
robotic321's Avatar
FRC #1793
We have a 3 terminal swithc and im think its going to be used for autonomous alternative selection. All i know is that its fun to play with right now.... but i need to find out how to wire it in to the system
1793 FTW
Unread 15-02-2011, 15:03
MrForbes's Avatar
AKA: Jim
If you are wiring it to a digital input, you could connect the white and black wires of a PWM cable to two of the switch terminals that are next to each other.
Most switches will close the circuit between the middle terminal, and the end terminal opposite the position you move the lever/rocker.
Use an ohm meter, and see what it does.
Unread 18-02-2011, 15:09
robotic321's Avatar
FRC #1793
Red face Re: How do I wire a Toggle Rocker Switch
Much Appreciated
1793 FTW
