Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 15-02-2011, 18:32
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Autonomous Problem saving power values
When opening the Autonomous vi front panel by default all the values are negative. I change them to positive values and run the program on the robot and it works flawlessly. Then I attempt to save it, but it always goes back to the negative. How do you change and save those values?
~Team 1529 Cybercards~
Unread 15-02-2011, 18:33
Re: Autonomous Problem saving power values
After you've entered the new value, right-click on the control, select data operations then select make current value default.
Unread 15-02-2011, 18:34
To save all the front panel values, click "Edit -> Make Current Values Default"
To save only one of the front panel values, right click on it and go "Data Operations -> Make Current Value Default"
Unread 15-02-2011, 19:06
FRC #1529
Thank you!!
