Go to Post If you find yourself extremely upset, frustrated, angry, or any other term of emotion, please stop and ask yourself why you participate in FIRST. - indieFan [more]
Unread 15-02-2011, 16:31
Howard1502 Howard1502 is offline
FRC #1502 (Technical Difficulties)
Team Role: CAD
Howard1502 is an unknown quantity at this point
Constraint Problem
Hello all! On Inventor, I was in an assembly and attempting to constrain an electronics board to a platform they were supposed to be on. When I used the face constraint, using the bottom of the electronics board as selection 1, and the platform for selection 2, it seemed to work. However, when I zoomed in, it was not fully constrained. It was at an angle leaving a small part of the board still off of the platform. I cancelled the constraint and tried again, and it did it again. Both parts are completely flat on the faces I constrained, and even when I used the angle constraint to attempt to make it go flat, it just went through the bottom of the platform. After that, I made a "plane" on the bottom of the board, and the top of the platform and then constrained, but it still didn't work.
Any suggestions on how to solve this?
Thanks!
Howard
Unread 15-02-2011, 17:59
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Constraint Problem
So, that constraint you've been doing should be kept, it's just not the only one you want to use. all you're saying to inventor is make the point you selected in contact with the other point you selected. There are a few ways to handle this, some of them are not very good long term solutions depending on your constraints, but you'll need to do some guess and check on all of them:
1. if the top of the platform is flush with another spot, you can flush the board to that location.
2. make holes in the platform and the board, and then constrain those together.
3. using the second button on the constrain type list, angle, select the top face of the board and the top face of the platform. Before you click both faces, make sure the solution is set to Directed Angle, as opposed to the default Explicit Reference Vector. Then make sure the angle is set at 0 (that should be the default).
One of those/A Combination of those should work.
Hope this helps,
-Duke
P.S. If this did not help, please help me know, im happy to try and help more.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 15-02-2011, 19:26
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Duke461,
Good suugestions. Howard, any further problems I can have a look at the file and provide a solution.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 17-02-2011, 16:20
Team Role: CAD
Originally Posted by inventor_phild View Post
Duke461,
Thank you for the suggestions Duke, I really appreciate them! But I'm still having the problem of constraining.
"inventor_phild", if you would be willing to help me out if I sent you the file, that would be greatly appreciated also! Just let me know how/where to send the file to and I would be very happy if you'd help me with this problem I am having.
Thanks!
Howard
Unread 17-02-2011, 16:28
0zymandias 0zymandias is offline
FRC #1712
0zymandias is an unknown quantity at this point
Are you sure the bottom of the part is actually flat? Did you CAD it yourself? I know I spent way more time than I'd have liked last year trying to constrain a part that wasn't made in a CAD program and just wasn't quite straight. Have you tried constraining from the origin planes of the object rather than the faces?
Unread 17-02-2011, 17:13
Team Role: CAD
I did not CAD it by myself, but I have tried work planes, regular planes, original planes, etc. I have tried many things, but it just doesn't seem to be working. It seems like I'm missing something simple, because I feel it shouldn't be this difficult.
Thanks anyways!
Howard
Unread 19-02-2011, 21:23
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Attach the files here - I guarantee there is a problem with the parts. (or you've zoomed in beyond the capabilities of you graphics card.) My bet is on a problem with the parts.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 23-02-2011, 18:15
Howard,
If you attach the files there are a couple of us who will look at the issue.
You can also email me the files at,
phil.dollan@autodesk.com
Phil Dollan
Autodesk Inc.
