Go to Post You can build bridges, or you can burn them. The choice is yours. - dlavery [more]
Unread 14-02-2011, 08:43
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Compressor Durability
It looks like this year we are going to be using a lot of pneumatics and the compressor is going to be running the entire match. Is there any benefit to trying to code, drive, design, ect. things on the robot so that the compressor isn't running for a solid ~2:30 minutes? Specifically will running that hard and hot put any wear and tear on the compressor that it can't handle?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 14-02-2011, 08:48
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Compressor Durability
Which compressor are you using, the new smaller one, or the one that came in the kit up until 2009/2010?
We're using one of the older compressors and have never had a problem with it - even when it was running nearly non-stop during the match. It will heat up a bit, but that's as to be expected.
-Dustin Benedict
Unread 14-02-2011, 08:52
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
I believe we are using the older one, but I'm not sure. Do you think the smaller one could present any overheating problems or something like that?
Unread 14-02-2011, 08:55
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We have never had any problems with the old style compressor. Our Overdrive robot ran the compressor the entire match and the only problem we had was running down our batteries
Unread 14-02-2011, 09:13
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
The old one is nice and rugged, just be careful at times that thing gets HOT!
Unread 14-02-2011, 09:17
thefro526's Avatar
Mentor for Hire.
Most teams don't have experience with the new style compressor, so they can't speak for them.
As you can see from the above posts, those older compressors are solid.
-Dustin Benedict
Unread 14-02-2011, 12:25
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Given that you have the weight. A way of keeping from operating the compressor for the entire match is to include more on-board storage.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 15-02-2011, 19:25
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
I looked at the newer compressor's spec sheets, and it has a 9% duty cycle. We are going to compensate for this by mounting a fan from an old vick over the heat sinc on the top.
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 15-02-2011, 19:48
dtengineering's Avatar
AKA: Jason Brett
So long as you've "got enough air" to power your pneumatics throughout the match I wouldn't worry too much about compressor abuse. You may want to keep in mind, however, that the compressor draws current "away" from your drive train and other systems while running. As you can see from previous posts, that shouldn't be a problem as far as reliability is concerned, but you could also set it up so that when your drive system goes to maximum power that the compressor briefly turns off. If your programmers are already up to their eyeballs in other challenges then its not worth the effort, but you could see a slight increase in drive performance.
To conserve air you might want to consider how you could hook up some of your cylinders as "single acting" (with a spring/elastic loaded return, rather than a pneumatically driven one) or run a second regulator to provide lower pressure air to cylinders that don't need a full 60 psi. If you keep the distance between the cylinders and valves short that also saves venting the pneumatic lines at the same time you vent the cylinder. When you are short on air every cc counts!
Jason
