Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 15-02-2011, 20:23
Red One's Avatar
Red One Red One is offline
missed the site deadline.
AKA: Pete Almanza
FRC #2950 (The Devastators)
Team Role: Webmaster
Red One is an unknown quantity at this point
Style code trouble!
I have two pages that I recently validated through W3C and had the validator clean up the errors for me. Those two pages were uploaded again to the main site but the background color became black instead of the original color of purple. I tried inserting just regular bg color code but that didn't work.
<style type="text/css">
/*<![CDATA[*/
body.c8 {background-color:#37007b}
p.c7 {margin-left:-325px;}
div.c6 {margin-top:-50px; margin-left:-50px;}
img.c5 {margin-top:-301px; margin-right:15px;}
img.c4 {margin-left:-324px;}
p.c3 {float: right; width: 50%; text-align: center;}
p.c2 {float: left; width: 50%; text-align: center;}
img.c1 {margin-right:330px}
</style>
This is the style type that contains the error. Note that the bg color is set to the custom value. This is the other style for the other page I happened to correct( I attempted copy and paste but had no luck either):
/*<![CDATA[*/
body {background-color:#37007b}
p.c5 {margin-left:-325px;}
div.c4 {margin-top:-50px; margin-left:-50px;}
div.c3 {text-align: center}
p.c2 {font-size: 144%}
</style>
If anyone has an idea of what could be wrong, I would greatly apprecitate the help!
Sometimes we crash and burn. It's better to do it in private.
-Dean Kamen
Unread 15-02-2011, 20:51
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Style code trouble!
Could you clarify which block of code is working and which isn't?
Try comparing the selectors in each blog. For example, the first one has styles for
body.c8
which means they will apply to the body tag only if you have
<body class="c8">
in the HTML. In the second block, the selector is just "body", meaning that it will apply
to the body tag regardless of its classes.
If you compare the selectors as well as the classes used in the HTML itself, that might explain the results you're getting.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 16-02-2011, 21:18
perlgerl perlgerl is offline
Michelle
FRC #0781 (Kinetic Knights)
perlgerl is just really niceperlgerl is just really niceperlgerl is just really niceperlgerl is just really nice
Did you miss the semi-colon? eg
body.c8 {background-color:#37007b;}
Unread 16-02-2011, 21:38
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Normally, you don't need the semicolon for the last one. You only need it if you are separating multiple styles for the same thing.
I'm right 90% of the time, so why worry about the other 3%?
Unread 16-02-2011, 21:50
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
i would say add semi colons to everything and remove the /*<![CDATA[*/ & /*]]>*/ (What is that stuff even for?)
Unread 17-02-2011, 01:20
7
FRC #1712 (Dawgma)
Yup, the CDATA stuff is not needed--but in this case, both lines are /* commented out */ so they won't impact the CSS.
And Cecil is correct; the last semicolon in each block is optional.
