Go to Post How about "The 2007 FIRST Robotics Competition International World Championship Event Of Atlanta Consisting Of Competition, Gracious Professionalism, Robots, And Geeky Fun"? Somehow I doubt it will catch on... - raymaniac [more]
Unread 15-02-2011, 19:25
MisterL's Avatar
MisterL MisterL is offline
Robot C Master and Mentor
AKA: Derrick Canfield
FRC #1544 (One Byte Short)
MisterL is an unknown quantity at this point
Question Java Pneumatics
I was told this year I have to program our compressor and Solenoid for our robotic arm. I only programmed ROBOTC for FTC before. We have nobody experienced in Java and while we have a drive program I can't for the life of me find out how to program pneumatics. Can anybody help me out even if its a little?
(This is my first post, sorry if its done wrong)
"Doing Java from scratch with no previous experience with it? Piece of cake!" Famous Last Words
One Byte Short Mentor
Unread 15-02-2011, 21:11
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Java Pneumatics
For the Solenoids, the first thing to do is to create the Solenoid object. The constructor follows the general WPI format, with options to create it based on slot (of the Solenoid module) and channel, or just by channel.
Solenoid armSol = new Solenoid(7,4); //creates a Solenoid object in slot 7, channel 4.
After that, there are only two functions to concern yourself with: get(), which returns the current state of the Solenoid (true or false), and set(boolean on), which sets the state of the Solenoid.
armSol.set(true); //turns the Solenoid on
The compressor can take up to four parameters, because it has two 'things' to set: the location of the pressure switch (what reads the pressure and tells the robot when it's 'full'), and the location of the relay (what turns the compressor on or off). After that, start() the compressor object and it should automatically regulate itself, turning off when the pressure is high enough, then restarting when it drops. You can get the value of the pressure switch and the state of the compressor with getPressureSwitchValue() and enabled(), respectively, but for safety reasons you cannot control the actual state of the compressor manually.
Compressor aCompressor = new Compressor(1,1); //create a compressor with the default slots and relay and pressure switch channels 1 and 1.
aCompressor.start(); //start the compressor.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Last edited by Patrickwhite : 15-02-2011 at 21:20. Reason: I may or may not have completely forgotten the compressor.
Unread 16-02-2011, 11:29
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Java Pneumatics
My double and single solenoid class
package com.shadowh511.mayor.outputs;
import edu.wpi.first.wpilibj.Solenoid;
 * @author sam
public class MySolenoid {
    private Solenoid foo;
    private Solenoid bar;
    private boolean doublek = false;
     * For a one-solenoid system
    public MySolenoid(int port) {
        foo = new Solenoid(8, port);
        doublek = false;
        System.out.println("MySolenoid enabled on port " + port);
     * For a double solenoid system
    public MySolenoid(int port1, int port2) {
        doublek = true;
        foo = new Solenoid(8, port1);
        bar = new Solenoid(8, port2);
        System.out.println("Double MySolenoid enabled on ports " + port1 + " and " + port2);
     * For a double solenoid system, custom slot
    public MySolenoid(int slot, int port1, int port2) {
        doublek = true;
        foo = new Solenoid(slot, port1);
        bar = new Solenoid(slot, port2);
        System.out.println("Double MySolenoid enabled on slot " + slot + " and ports " + port1 + " and " + port2);
     * Extends the solenoid
    public void extend() {
        foo.set(true);
        if(doublek) {
            bar.set(false);
     * Retracts the solenoid
    public void retract() {
        foo.set(false);
        if(doublek) {
            bar.set(true);
     * Gets the state of the first solenoid
    public boolean get() {
        return this.foo.get();
     * Gets the state of the other solenoid
    public boolean getOther() {
        boolean eggs = bar.get();
        return eggs;
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 16-02-2011, 18:11
MisterL's Avatar
Re: Java Pneumatics
Thank you! Those both were very helpful!!!!
